I am trying to polish my first stainless steel case but am not succeeding very well and hope you can give me some good advice. But before I describe the problem itself, I want to explain how I proceed because the solution to the problem may lie in something I do or use before the actual polishing.
This is what the side of the case looks like before I start. As you can see, several scratches of different depths and cavities exist. The watch has been regularly wound up with a metal crown winder which has left circular traces (this watch houses an ETA 2763 manually wound movement).
To get a smooth surface before I start with my rotary tool (Proxxon Micromat 230/E), I sand down the surface using wet sandpaper with increasingly fine grain. For this purpose, I have made a mini sanding block out of solid aluminium around which I wrap the wet sandpaper. I got the inspiration for the sanding block from @nickelsilver in this post (👍). In this case, I started with 180 grit and finished with 2000 grit.
The mini sanding block makes sure I don't risk rounding the edges of the case. The sanding requires a lot of work, but still not as much as I feared, and the result is exactly as I hoped.
Time to use my rotary tool to get a high gloss finish. As a polish, I use Polinum which is meant for platinum but still seems to work well with stainless steel. I have also tried green Dialux but got the feeling that Polinum is more efficient and gives a better result, but maybe it is the polishing agent that is the problem.
I have tried polishing with two different types of polishing wheels cotton and felt.
When I use the felt wheel, the main part of the surface becomes very glossy, but as can be seen from the picture, there are also small indentations in the metal that can only be removed with wet sandpaper.
When I use the cotton wheel, the results are slightly better but still scratches the metal.
From a short distance and depending on how the light falls on the housing, the damage in the metal is not visible, but I believe that the surface should pass a close inspection regardless of which direction the light falls from.
So, the question is, what am I doing wrong and what can I do differently?
How fine of grain sandpaper are you finishing with? It's important to "cross the lines", go in different directions, so you can see when you've really erased the last grit's grain. Then, if using a micromotor, you really have to go fine with the paper or it's going to be painful. This would go better with a large wheel (hard felt) on a buffer.
You also have to change directions with the buffing. The polishing can actually augment remaining defects, which just get bigger if always going the same direction. And sometimes it just goes all orange peel and you have to go back to paper.
Having the right paste for the metal is good, but there's a lot of voodoo superstition around that. Good technique is a bigger deal.
17 hours ago, RichardHarris123 said:
Are you sure there's no contaminants either on the wheels or in the Polinum itself?
Well, I guess the wheels I use with my micromotor become contaminated with metal residue pretty quickly. This is especially visible on the felt wheel as seen in the picture which very quickly becomes black. I assume the "black goo" is metal residue, no? I don't see how that can be avoided. Also, when charging the wheel with the polishing compound there's some slight black residue of metal on the compound as well as can also be seen in one of the pictures. I'd be happy for any advice!
As I mentioned in my post I start with 180 grit, then 240, 320, 600, 800, 1000 and finish with 2000 grit". So, 2000 grit.
The wet sandpaper I use with my square aluminium sanding block seems very efficient. It doesn't take much to erase the grain of the previous grit. Once I have finished with the 2000 grit paper I have a very flat, smooth, and mat surface. The gloss is what's missing and is what I fail to accomplish with my micromotor.
Not sure I follow you here. I'm not trying to remove dents and scratches with my micromotor if that is what you're referring to, are you? I only use my sanding block to remove scratches and dents using increasingly finer grit sandpaper which I keep moist and clean with fresh water.
I believe the terminology is confusing me. Would polishing mean removing dents and scratches, and buffing creating a glossy/shiny surface?
It's the technique I'm trying to get to grips with so if you guys have any additional advice or clarifications you can share I'd be super happy!
I really thought removing the scratches and dents would be the hard bit, and the "getting it glossy and shiny" the fun and easy bit. If there's one thing I learned over the years it is that in watch repair it is always in the unexpected where the challenges are 🤨
Edited by VWatchie
2000 grit should be fine enough to start polishing/buffing (for me the terms are interchangeable 🙃). But it can be quite challenging to polish with such small buffs. Even doubling the diameter would help.
I just ordered this polishing machine from Holland (ToolsIdee) including the protective hood. The wheels are 100 mm in diameter and I think and hope that will suffice. The wait begins... (again). I will soon have to kick out my soon-to-be 18-year-old daughter from her room to get my workshop. She's studying in Tokyo right now and I'm itching. Need to make room for a lathe too 😆
Are you washing between different grits and polishing?
I carefully wipe off the surface I have been working on with a certain grit before I go to the next but I don't really wash it. However, I continually keep the sandpaper moist and clean by dipping it into clean water which I do several times while working with the same grit.
It helps a lot to be able to inspect under a microscope.
You've really got to avoid contamination from coarser grit when moving to finer.  Wiping really isn't enough.  There will still be bits stuck around edges and crevices than get picked up when buffing and leave scratches.  I run though the ultrasonic.  It's very tedious.
Try a larger diameter felt buff.  That one looks like ½" diameter.  I find the 1" work much better.
The small indentations look like maybe the metal is smearing.  If you run the buff too fast, with too much pressure, and for too long without putting fresh compound on it, this seems to happen.  More buffing isn't necessarily better.  The compound doesn't really last for the long before it's used up and doesn't cut anymore.
I think some metal just isn't as good.  It has inclusions or carbides or something in it.  Under the microscope you can see little pits, with scratch trails running from them in the direction of the buffing that weren't there when sanding.
I found this site to have pretty good information, https://www.struers.com/en/Knowledge/Grinding-and-polishing#
I sometimes just use autosol instead of dialux. The abrasives in autosol breakdown into smaller particles as pressure is applied, so you don't have to change polishers or change grit. And when my polishers really look dirty, like when the black stuff gets shiny, I just ultrasound them in a jar of petrol.
Thanks for your input, much appreciated! Instead of running through the US, I'd like to know if a very dense, fine-bristled toothbrush, washing-up liquid, and hot water would be enough. If so, that could possibly speed up the process.
The polishing machine I have on order should take care of that, but really good to know that the diameter is important (also indicated by @nickelsilver)
Although these small buffing wheels are inexpensive I did wonder if and how they could be cleaned. Especially as you need to replace them quite often, and "small streams make great rivers". I do have a tube of Autosol so I'll be giving it a try.
Good results removing fine scratches can be achieved just with autosol and manually buffing with a soft cloth.
  • 5 months later...
@VWatchie, did you ever figure out the issue with your technique? I'm having very similar issues when I start using the polishing compounds. I'm sanding all the way up to 2000grit and don't see any noticeable marks after that. As soon as I start using polishing compound (I've tried dialux  grey then white and also grey, blue and then green) those little dots and other similar blemishes appear. Did the larger polishing wheels and less pressure solve the problem for you?
100 % yes! As seen in this post, I gave up the idea of polishing using a rotary tool and got myself a proper polishing machine.
Achieving extremely shiny surfaces without the slightest trace of scratches is very difficult but fortunately the scratches are invisible to the naked eye and only visible under high magnification (10X or more).
I am very happy with the level I have reached. I will try to write a bit more in detail about the techniques I use but I don't have time right now. I will return with a link in this thread when I have done so.
Here you can see examples of what I recently achieved with my polishing technique.
I wish I had space for a large polisher 😟. I have to make do with a Dremel type tool, but am very happy with the results. It's just a question of how much abrasive and the pressure.
Depending on how deep the scratches are, I'll start with 600 grit and work to about 1000 or 1500. Then I used hard felt wheels with Dialux white. For final polishing (Dialux white) I find the small chamois wheels excellent (they are ideal for polishing gold too).
I realised that looking under the microscope for scratches when final polishing was a mistake, only the naked eye matters. And a couple of wears and micro scratches will be back.
I have only had this problem once or twice. I think it might be something to do with the crystaline structure. As Nickelsilver notes, you need to change direction. Once I figured that out, I didn't have a problem.
Edited by mikepilk
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
    • At the moment I have neither EDTA solution nor Evaporust, so I tried with a citric acid solution. This gave satisfying results for most of the parts, except for the ones that are really heavily corroded. I will see whether I can acquire one EDTA or Evaporust and try that next.
    • This guy (Minimachining) has a playlist of him setting up and using various attachments on his Sherline lathe.   I know nothing about CNC machines but had a question about making screws. Watchguy.uk has a section on his website where it allows you to enter parameters for screws and wheels and then 'generate code'. Is it as simple as that sounds, can you 'tell' the CNC machine to cut you a screw (or stem) by giving it the code for a particular screw or stem and it happily makes one for you?
