Hi all from Lincoln - UK
Good evening all, I look forward to chewing your experienced ears off as I start my horology journey.
I've an ideal sized home office which is going to be turned into my workshop so as a typical bloke, im looking forward to purchasing my tools and getting the movements I do have running a hell of a lot better.
One project I've got and am keen to do is a Waltham pocket watch passed down to me from my grandad, it's hammered so will be a real labour of love to get this running and looking beautiful again.
Anyhow, I've rambled on for long enough, I know where the search tab is so I'll be reading, studying and thoroughly enjoy my time here.
Cheers
Steve
Many thanks for the welcome 😃
Well, my journey is starting on an old replica Planet Ocean I've had lying about for the past ten years.
Im going to get familiar disassembling and (trying) to reassemble the movement, taking pictures along the way.
Hopefully it'll get me familiar with things before I move onto decent stuff.
Looks like you are on your way, remember we are here to help, and offer our 100s of years of combines experience. My golden rule "if you are forcing it, you are breaking it!" A lesson i repeatedly learned the hard way!
Noticed you don't have one of these:
Cheap as chips, and worth its weight in gold, use it for opening 90% of my watches with zero risk of slipping/scratching.
Hi mate,
I've actually got one, and the Rolex dies including the Deepsea Sea Dweller. so casebook removal is taken care of 😀
Some of my stuff is in the drawers below.
I just need to get an overhead camera/phone desk mount so I can record disassembly of the movements as im bound to come unstuck!!
I visited the little display at the old Waltham factory today. Here is where your Watch was made! From just a few hours ago…
…my trip was otherwise a dud. I tried to visit the Waltham Museum where I thought there was a Depollier and some pocket watches. Unfortunately the doors were locked during visiting hours. Government efficiency wins again…
Here’s a peek at the watches owned by a friend, passed down from ancestors who worked at the factory…
    • Ah so its you thats buying up all the DD calibres 🤨.
    • Hi Richard,  I keep buying CAL.59 movements to practice on 🙂 Not started yet though, I'm gathering tools and building my confidence to start.
    • Problem solved. For some bizarre reason, the hook on the wall of this barrel is not properly centered vertically, but is oddly high on the wall, maybe 3/4 up the way up. When replacing the mainspring, this caused the outer coil to be displaced upwards as well such that it protrudes out of the barrel and caused the barrel lid to not sit quite flush to the barrel. Since this is a motor barrel, the lid is actually the first wheel and inner coil tube/hook all in one piece, with no “snap down” action that would have made the problem more immediately obvious. Maybe with an older mainspring the spring’s end hole was enlarged such that this wasn’t an issue, but hard to say how it ever worked otherwise. Replacing the barrel with one from a different model 1900 where the hook was properly vertically centered allowed the lid to sit flush without mainspring interference and the friction problem went away. The bridge was far too thick to be bent (and isn’t), for those of you thinking that was the problem. Placing the removable arbor in the watch without the rest of the barrel proved that the proper end shake was actually there as long as the overall height of the assembled barrel was correct.
    • You are so true on a lot of what you have said. The main reason for changing the mainspring even if the old one is in good order is because it will take out your thinking that the mainspring is contributing to poor power output or fluctuations in amplitude. If a new spring is fitted that box can be crossed off as a potential source of a problem. Most customers are happy to pay the extra £20 for a new mainspring if they are already parting with a couple of hundred pounds for a service. A new spring is an investment for good running for the future.
    • According to Borel the 814 and 815 use the same escape wheel. It's kind of an oddball being so long.
