This is how I sharpen pegwood
I have never enjoyed sharpening pegwood. I get wood chips all over the bench, floor, clothes and places you never even imagined.
I recently found a mechanical pencil from my secondary school days. These dinosaurs use 2.0mm leads, which set me thinking.... Can I put a toothpick into it and stick it into my pencil sharpener to sharpen it?
This is what I got.
I just discovered that AliExpress still sells these antiques. I ordered a 3.0mm version for my pegwood.
I sometimes use an ordinary pencil sharpener to get a rough tip, but then to get the tip fine enough to go through small jewel holes, I have to work under the microscope with a sharp blade. Often it breaks off at the first use, then I have to do it again, and again. I hate pegging holes 😟
Amen to that!
If someone could come up with a device or a method that could sharpen peg wood quickly and easily to the point it could be used to peg pallet fork bridge jewels I'd be willing to pay good money for it. It's such a PITA 🙁
23 minutes ago, VWatchie said:
Amen to that!
I've just been doing that exact job this morning - pegging pallet and escape wheel holes 😟
Just getting the tip sharp enough to go in the pallet hole is difficult, then it immediately breaks, and start again  argghh
  • Sad 1
OK this may be a crazzzzzzy idea.... but what about if you used a fiber to 'peg' the jewel hole instead of wood, a scaled down version of something like this:
Obviously the fiber would have to be selected not to leave behind fibers, and the 'needle' small enough to pass through the jewel hole (not sure how feasible this bit is), but I bet it would do a better job of cleaning? Just run it through then use it like flossing your teeth.... hey there's a thought dental floss!!!
Thoughts?
Could use something like a sim changer below tool to poke through the 'dental floss' the floss the hole ???
WatchFloss©
haha
Edited by Waggy
Thoughts?
Escape wheel, pallet pivots must be about 0.1-0.2 mm?  What could you find small enough to go though that ?
56 minutes ago, markr said:
Wait. Now I have to lie to two people when they ask if I floss regularly.
You can lie all you want but as a dentist, we can tell whether you floss or not. When we ask whether you floss regularly, it's rhetorical.
  • Haha 3
Typical wristwatch escape wheel pivot is around 0.1mm, similar or smaller for pallet fork. Definitely too small for a needle and thread, and too small for machine sharpened peg wood. I use a standard snap-off cutter, but use the extra sharp NT Black blades- really makes a difference on peg wood. Also, different pieces of peg wood even from the same batch sharpen up differently. I have old stock peg wood and new stuff from Horotec, some pieces are great, some so-so, no real difference between the 30yo stuff or new.
The smallest needles i use and can find are acupuncture needles at 0.18mm thats going to be around double the diameter of an average WW balance or escape wheel pivot with a jewel bearing hole a hundredth maybe 2 bigger. Possibly go through a big pocket watch pivot hole but there is no eye for threading. Yep definitely flogging a dead os, good thinking outside of the box though.🙂
My dentist once asked if I'd be ok to have some work done without any  anesthetic to which i agreed. He said if i started to feel any pain just to raise my hand, i said no problem i shall raise it to just underneath your throat. 🙂
I have another crazzzzzzy idea.
What about using cactus thorns?
I've been going to garden supplies and looking at cacti. But I guess we don't get many varieties here in Singapore. Any one living near a desert?
We have cacti in Texas
A beard whisker is about the right size to poke through a jewel hole. Organic and low carbon footprint.
Was thinking about fishing 2 lb mono-filament or copper winding wire 0.1mm
I did look at guitar wire, but the thinnest I could fine was high E of 0.008" = 0.203 mm, so not a good candidate
I think we'll just have to accept that a really sharp blade is the quickest and easiest way to sharpen peg wood for those < 0.1mm pallet staff jewel holes and chaton holes.
So, I just ordered these blades (same as in the picture) and a cutter for them on eBay from Japan. I'll try to remember to report back to this thread once I've tried it (delivery is 1 to 2 months)...
eBay item numbers: 254266416996 and 254262491217
Edited by VWatchie
@HectorLooi, being that you are a dentist, I'm actually shocked you haven't thought of this already... a WaterPik!  What could possibly go wrong?  🤣
In all seriousness though, I thought the whole point (pardon the pun) of pegwood was to have something uneven to help clean out the holes.  If you used a pencil sharpener and it was all uniform in shape, you sort of take that away.  I think using a knife, scalpel, switchblade, machete,  etc is really the only way that you will get that.
I did try using a pressure jetting method of cleaning. I used a vintage glass syringe, as I didn't want to put any cleaning solution in my waterpik. But the results were not good. It cannot remove dried up oils.
And for those who think the waterpik is the answer to flossing, it isn't. The waterpik can only remove loose food particles. It can't remove plaque, it can't remove food particles pinched in the contact area of the teeth
I was taught that too. But when I thought about it, with the pressure applied when the pegwood is rammed into a hole, whatever facets on the tip would be crushed until it ends up smooth and round. Just look at the pegwood when it is removed from the hole.
We were all taught things that have no scientific basis. We need to sit down and distill fact from fiction.
Edited by HectorLooi
Typo
Damn! You went from preach'n to medl'n
You're 100 per cent right about that! The only exception is large jewel holes like those for centre wheel pivots. Still crushed, depending on the pressure applied, but not as much as for small jewel bearings.
The multi angle aspect of pegwood has been mentioned many times by professionals on the internet. Maybe its just that initial extra edge when starting to peg out before it takes a uniform shape. Some pegwood is harder than others and take longer to lose the cut angles. 🤷‍♂️
Anyone tried steam to preclean the main plate and jewels? Something similar to the below? Maybe there is a smaller version or an attachment that would allow you to get into the nooks and crannies of the movement (pre-roving or avoiding anything with shellac of course).
    • Yes, barrel size.  A 11mm spring will push out into a 11mm barrel, no need to go 0.5mm smaller.
    • Hello All, I’m looking for advice about how to interpret the mainspring specs described in the GR documents and in the catalogues of online sellers such as cousins.  My problem relates to interpreting the value describing barrel size - I’m unsure what the last number REALLY refers to.   For example: 1.10x.0105x360x11  (This refers to GR2628-X) Does the “ 11 “ here refer to the barrel inside diameter of the calibre OR to the diameter of the wound mainspring before insertion? For example if my measured barrel inside diameter to 11mm, I would normally select a wound spring size a little smaller, say 10.5, wouldn’t I?  Or, does the barrel diameter described in the catalogue specifications take that into account and I would therefore order a catalogue size 11 for an 11mm barrel ID? Hope this makes sense. I can’t find clarification of this anywhere. Many thanks for any enlightenment. Cheers, John
    • Let's say, like in a watch, you have  a 70 tooth 4th wheel, which needs to make a turn in one minute, with an 18,000 beat escapement. 15 tooth escape wheel as usual, and a 7 tooth pinion on it.   70 x 15 x 2 /  = 300  That's 300 beats, and there are 5 beats per second, so divide and you get 60s, one minute- all is well. If we do 70 x 15 x 2 / 8 that equals 262.5. With an 18K balance, which will let the escape wheel move one turn in 6 seconds, the 4th wheel will have made like 1.14 turns. So the time display is running fast. But this comes to like 7.5 seconds over per minute, which is about double your gain (maybe I'm wrong- I'm mathing on my phone while writing on my phone 😄) but pretty sure the gain is more than you are observing.   A possible culprit is that crown/4th wheel isn't running true, and a tooth is slipping past a pinion leaf once per revolution. I've seen this. If the platform is original and it's a nice piece they are often pinned, so the depthing isn't an issue. If the platform isn't pinned, check the depthing. And at any rate check the crown wheel between centeres and make sure the teeth are running true.
    • Fast responses - thank you. Yes, I mentioned the 18000bph to illustrate that it's not a matter of touching coils, over banking, shortened hairspring etc. I even took off the platform and temporarily fitted a another NOS one also with 8 leaves and beating 18000 but the colossal gain is the same. I'm resigned to buying and fitting a new Gorge platform plus a 7 leaf pinion escape wheel but only if I think it will work; otherwise it's a waste of £200 and a couple of hours work. Hence the underlying question is: all other things being equal, what would the timekeeping effect be? Is it a simple 7/8ths as fast? Logic tells me it is but can it be that linear?
    • Sorry to jump in here guys, but I've read through this whole thread and it seems there are a lot of people who think joining Facebook means everyone will have access to their lives. You could make a Facebook account with a fake name. You could even use your real name if you wanted to and set it to completely private so people can't even find you in a search and you don't have to add anyone as a 'friend', so you won't see anyone's posts. Literally use it to join a group full of members of this site. Admins could even set the group to private and require a password of some sort to gain acceptance into the group, so you can be sure that it's only members of this site that get in. @tomh207 is right, the form with email addresses and names is a bad idea. That will be abused by scrapers. Facebook is only as personal as you let it be. You can be completely anonymous on there if you wish. Don't think of it as Facebook. Just think of it as a watch repair group as that's all you'd use the account for. It doesn't even have to be set up with your current email address. Make a random one on Gmail or any other free provider just for the Facebook account. Tagged you by accident and now it won't let me remove it 😂 @Neverenoughwatches
