Toshiba TV dead.
So video said get numbers off old board and order new board.  Looked on eBay and found a guy who will repair mine for $55.  He's done 117 and has 100% feedback so I think it's the way to go.
Thanks everyone.
So, electrolytic caps deteriorate over time. For linear power supplies, this is not a serious abrupt problem. However, for switch mode supplies which are 99% of the market, aging caps are a problem because ESR increases and the supply shuts down.
I have repaired my Samsung 42" twice...both times--caps.
I don't use it any more because I got a modern huge tv.
11 hours ago, markr said:
First you people are geniuses and someone here will know what to do.
in the old days of television repair that used to be companies I would publish service guides for the various televisions radios whatever. Don't know if those companies even exist anymore? The problem with working on electronic stuff it's the same as watch repair with a blindfold on your success is not guaranteed unless you can see what you're doing and you can't see what you're doing without the schematic unless well sometimes you can is have to be lucky or know what the problem is.
12 hours ago, markr said:
older TV
you didn't say how old? I would start with the power supply but as it looks like a new design television the power supplies can get to be quite tricky then we go back to it be nice to have a schematic.
4 hours ago, oldhippy said:
This way I don't have to buy a licence to line the corrupt BBC
this is America we don't need a license or have a corrupt BBC. but don't worry I'm sure we have somebody that's corrupt somewhere that's going to steal all of our money in the name of greater good.
T V these days is just full of rubbish programs. I think its better that it doesn't work. I don't own a TV I haven't had one for about 15 years.
then was so much stuff streaming do we even need a TV anymore?
in other words the days of the bad capacitors. Strangely enough the Samsung monitor I'm looking at had to replace the capacitors but it's been fine ever sense.
6 hours ago, oldhippy said:
T V these days is just full of rubbish programs. I think its better that it doesn't work. I don't own a TV I haven't had one for about 15 years. This way I don't have to buy a licence to line the corrupt BBC.
Rawhide at noon, Bonanza at 1:00, Gunsmoke at 2:00, Rifleman at 2:30...what's not to like?
Bad guys dead within 30 minutes or an hour!
Edited by LittleWatchShop
Hello markr,
I had a Samsung tv which did something very similar. I would agree with the others that it's likely to be a capacitor. Though one thing I would try before you start unsoldering things is perhaps giving it a good clean and remove any dust. Though from you're photos it looks clean.
I limped along the Samsung for around two years with regular internal cleaning. It used to switch itself on and off when it felt like it. The cause was dust settling and shorting the legs out on the components due to poor design. A combination of badly designed vents to let out heat and poorly oriented components was perfect for dust to settle on shorting out the legs!
Good luck and keep safe
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
