An early 20th century Flemish carved oak and walnut longcase clock, height 240cms.
By LittleWatchShop · Posted
By Hawaiikook808 · Posted
By luiazazrambo · Posted
It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
