Greetings everyone!
whph4evr
The reason I joined this community:
My father recently gifted me his old broken watch. It's a Casio MDV-301D-7A (model number:2364), year 2007.
I managed to replace the battery, set the time and clean it thoroughly.
But there are other things I need to do, in order to restore this watch to a proper condition and use it for myselfI need to polish it and buy 3 different types of metal pins, in order to replace the broken ones.
Problem is, this is my first time repairing a watch ever. So I am not quite familiar with the terminology that is used for replacement/spare parts. I tried to do some research but I end up finding that everyone uses different names for the same parts (talking about the metal pins) or I end up finding no information at all.
I tried looking for a replacement bracelet, but they are discontinued worldwide. I also tried looking for a non-genuine chinese one, but no luck with that either.
With that being said, I am looking forward to my journey of learning about watches and how to repair them.
And hopefully wear this watch on my wrist.
Edited by whph4evr
  • whph4evr changed the title to Greetings everyone!
Welcome to the forum! As you are finding out, watchmaking is a deep, deep rabbit hole. It seems overwhelming at first, but the knowledge and readiness to help on this group is fortunately endless. Be patient, stick at it, help the experts to help you and you will soon have this watch back on your wrist.
Hello and welcome to the forum  If you have any questions regarding a watch/s we find it helpful if its accompanied with pictures of the said watch/s and their movements. Terminology differs as you have found out so I have attached a couple of documents which may help.
TZIllustratedGlossary.pdf 1913030912_TM9-1575WardepartmentTechnicalManual.pdf
TZIllustratedGlossary.pdf 4.2 MB · 0 downloads 1913030912_TM9-1575WardepartmentTechnicalManual.pdf 14.14 MB · 0 downloads
Wow, you just provided me with everything I need, in order to learn the whole anatomy of a watch! I don't think I will need to go so deep in that case, because I simply need to replace a couple of pins but I really appreciate you sharing your knowledge with me. Thank you very much!
Hey there is a original rubber strap for sale at ebay, check that out  https://www.ebay.com/itm/264643304484
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
