So a little bit of wear on these pivot holes!!!!!
First picture is the scape wheel and the second picture is the Fly on the strike side. So much wear so far up the train, even the hammer arbor has worn the plates
Edited by transporter
Phots didn’t add
34 minutes ago, watchweasol said:
Hi is this wear common throughout the clock.  Its pretty bad a lot of bushing to do, never seen a clock so worn the pivots themselves will be suspect.
Yep, it wear throughout the clock, both trains.
I was initially called by the customer to set their clock up after they had moved it from upstairs to downstairs.
On arrival the crutch was bent beyond belief where the husband had “got” it going after they had thoughtfully removed the pendulum and forced it back into place.
Its a longcase strike movement from wales dated mid 1700’s so it’s had a fair old life so far.
i will bush sympathetically and where I can without needing to make new components.
30 hour Longcase clocks always need a lot of work when it comes to wear, most likely the pivots are worn and the pinion's. Something not right in those two photos both pivots are not long enough for the plate, you might have a made up movement in other words parts that didn't start out together. What is the name on the dial and place.
It's odd that the holes are so round, while being so oversize. Perhaps in the past they were broached round, and the pivots retouched, but bushings not put in to compensate the new size difference?
As the wear happens the hole tends to go oblong, increasing the surface area touching the pivot (as well as shifting the centers).
Name on dial is Lewis from Llanidloes, researched from my Brittens old clocks and watches and it comes up with him from around the 1700,s
Wow I’ve really missed something with this clock……….
it’s running backwards!!!!!!
weight is set up as per the Huygens way, escapement running normally but minute hand going in reverse 😁
Silly me, I threaded the chain incorrectly, I’m driving the great wheel clockwise not anti-clockwise
    • Interesting, thanks for the detailed post. I saw one of those Swiss Nano machines a while back in another youtube video from  the Weiss Watch Company.
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
