Seiko 7625A keeping terrible time
There you are, thanks for showing up JersyMo, I knew you could help, as for the France manufacturing I'm sure a lot of manufacturers have facilities all over for different reasons...
Hi, the setting bridge looks similiar to a 7 3/4 Felsa 171, 8 3/4 Felsa 87r but the clutch lever does not, the closest I can find is the A. Schild 8 3/4 547, it shows two setting bridges and the correct shaped clutch lever, good luck with this project .....
a 1982 marlin - looks like it is missing the gold trim bezel -
Hi, there is a Timex expert on here but I can not remember his name, try the search bar at top right.....
