7 hours ago, Neverenoughwatches said:
Looking forward to using it as soon as i find a burnishing tool.
My first burnisher was a Vallorbe Swiss (Cousins code 3211). One end is coarse (for shaping?) and the opposite end is fine (for burnishing?).
9 hours ago, Mark said:
if you have a dual purpose pivot file/burnisher you can shape and burnish within a few strokes.
I would guess that the Vallorbe Swiss is just that, a "dual purpose".
Anyway, I believe it was @nickelsilverwho mentioned that the rounded edge of the Vallorbe Swiss was better suited for pocket watch staffs and recommend the Bergeon burnisher for wrist watch staffs. So, I got that too (Cousins code B33496). It's the Bergeon burnisher that I've been using, although I haven't yet burnished any balance staffs. The Bergeon burnisher has only one fine side.
I'm not sure the coarse side of the Vallorbe Swiss is really necessary as I can easily and pretty quickly reduce (shape) the pivot diameter using the Bergeon burnisher. Perhaps, using the coarse side of the Vallorbe Swiss would make it quicker to shape the pivot before burnishing, and maybe that's what you're supposed to do, yes, no?
I would be tempted to stick with something that reduces size,and shapes at a steady pace. It's so easy to overdo it with something of a too course nature. You can't  put back what you've taken off. We quickly learn with experience though how far a tool will take us before we need to switch to a different method. Appreciate the info on the burnishers Watchie. I've heard of jasper stones being used as a finish. I used to use Arkansas and washita stones for fine joinery chisel sharpening. I also have an extremely fine Welsh slate stone. I was thinking of taking a thin slice off them and dress them up to a good square edge. Tomorrow's project maybe. A bit to think about on a staff pivot, to keep  within its set dimentions. Diameter, length, conical shoulder, it's finished end shape.
Edited by Neverenoughwatches
Morning Watchie, I'd be curious to know how much detail you can create on a staff pivot with the Bergeon burnisher. What is the difference between the Vallorbe and the Bergeon, is it their abrasive ability ? would you mind putting up a photo of them please Watchie ?
Just had a look on cousins, not much detail on them and the pictures aren't much use. Pretty expensive for what they are.
Sorry but I don't understand the question and I haven't yet worked on any staff pivots.
The Bergeon has a single side burnisher whereas the Vallorbe has two sides, a burnisher side and a file side.
Comparing the burnishers I believe they have the same abrasiveness (although the surfaces of the two look a bit different). Of course, the file side on the Vallorbe is a lot more abrasive. Also, notice that the rounded edge on the Bergeon burnisher is smaller and better suited for wristwatch movements whereas the rounded edge of the Vallorbe burnisher is larger and better suited for larger, pocket watch movements, or so I have been told, but it makes sense.
It wasn't really a question Watchie i noticed eariler that you said you had not done anything with a staff pivot. I was just thinking through a post as to how much detail on a staff pivot was possible with the Bergeon that nickelsilver had recommended. Such as smoothing out the shaped cone of a pivot shoulder.
Those photos are brilliant thanks, that helps me to decide what to use. I was thinking of making something, maybe not possible looking at these.
The Vallorbe tbh looks like it has a slightly finer grain to it but more random as opposed  to the uniform grain of the bergeon.This maybe gives the vallorbe a more aggresives cut. What magnification are we looking at here watchie ?
One thing to remember about a burnisher, is that it is *not* a file. The point is not to remove material, but to compress and work harden the pivot.
Cheers!
Cheers!
When you burnish a damaged pivot, perhaps it has been scored by a cracked jewel or has rusted, it will diminish the pivot diameter. So, it will remove material! I'd say the typical situation in my experience is that you will need to remove 1-2/100 mm but more may be required depending on the situation.
Of course, there's a limit on how much you can remove from the pivot before the jewel has to be replaced. And there's a limit to how much you can remove before the pivot becomes too weak for its job. It depends on the original pivot diameter. Mind you, I do this with my Bergeon burnisher which, unlike the Vallorbe tool, doesn't have a file, just a burnisher. Please see the images in my previous post.
As an experiment practising with my Jacot tool and Bergeon burnisher only I have reduced the pivot diameter of a 0.17 mm pivot to 0.07 mm. So, it works as a file too but the end result, if done correctly, will be a pivot with a (very near) mirror shine.
I'd say the point is to remove as little material as possible.
Actually the textured burnishers used for pivot work can be seen as ultra-fine files. They do compress the metal, but they also remove some metal, that's the "black stuff" on the burnisher after some strokes.
A really fine textured burnisher will have a cutoff point though where it won't really remove material any more. A more aggressively textured one would continue to cut (and burnish)... but, it won't leave quite as fine of a finish on the part. The Bergeons are pretty spot on right out of the box. I had a Vallorbe when I was in school last century but as VW mentioned the radius is too large for most watch work, and the file is useless for watch work (maybe for a center wheel or barrel arbor?).
Ha VW posted while I was writing.
Edited by nickelsilver
I stand corrected 🙂 thanks!
I think I understand the cutoff you mention, if the pivot is work hardened the way I expect it should be,  a fine "file" will no longer cut.
And darn it, now I can't find my burnisher to check what I have. All this moving around ergh.
Cheers!
Found it. Vallorbe LP 3215 left handed. AF Swiss catalog calls it a double ended pivot file cut 000 to cut 8, when I bought it it was sold as a burnisher. Looking at it under the microscope, it's not very well made, or confusingly made. On end is definitely a file, and the other is a ground surface, pretty smooth. I don't have access to the stuff to check microfinish anymore, but it is pretty fine. The radius on the relieved edge is poorly done,  inconsistent, and on both sides part of the radius is serrated and part smooth.
Off to find a Bergeon burnisher!
Thanks
Aargh. Not now.
Now I know why I bought the Vallorbe. Best US price, $130. Cousins is better, but they are out of stock on the left handed one.
Cheers!
Eyup Dave how you doin mate ? Thinking about it as with my post earlier regarding the burnishers is that everything that has a surface must have a texture or a grain so in effect has its own cutting surface,  be it at a microscopic level if so . So in theory if one surface is harder than another ( higher up on the mohs scale) the harder surface will cut the softer surface. As with Watchies burnishers their cutting surfaces are machined to whatever is required, but even without their machining they would still have their own grained surface from being forged i guess. Nicklesilver's cut off point I'm assuming is when the burnisher's effectiveness has dropped off to the point where the pivot being polished has reached the finishing level that burnisher can achieve. Even with a mirror like finish on the pivot there would still be a grained texture visible at some level of magnification. Also to consider would be the hardening of the pivot, i can only guess that this has something to do with its structure being altered through heat and pressure.
Thats some reduction watchie, what was the turn around time for doing this ?
Work hardening, a tightening of the materials structure by pushing its molecules closer together ? The same is possible with timber.  Compressing anything will increase its density, whether its thoughtout its entirety or just a variable surface depth  as with a pivot. Tough hard outer shell with a softer center ( like me 😉 )
32 minutes ago, VWatchie said:
Interesting discussion! Still having problems with my health 🤒 I'll try to be back tomorrow...
Hope you feel better soon mate. Take good care of yourself. The discussion will still be here when you are ready to come back and join in.
The burnishing that I am familiar with outside of watchmaking is cold working of a metal, non abrasive.  There is such a thing as "roller burnishing",  there is almost no abrasion when doing that.
Work hardening causes similar changes to metal  as heat treatment,  deforming the metal with pressure changes the grain structure.
The goal is to create a hard, smooth surface.  Again, the burnishing that I know about deforms the metal so that surface defects are removed, and in the process hardens the surface of the metal.  The hard layer is sort of like what you get when you do "case hardening".
Cheers!
Cheers!
A bit of googling has come up with , plastic deformation. So the evening out of the peaks and troughs of a material.  Compression of the outer surface defects . I wonder if these burnishers then continue to cut their grained surface on the pivot. Maybe looking at this a bit too hard now to be of any more use lol. They cut, they compress, they harden. As long as they do their intended jobs. That extra knowledge i see as helpful in knowing what cheaper alternatives there are. Particularly in making something that is as effective as a high cost tool. They're really just a hard piece of steel with a micro cutting surface. Whats wrong with a seperate cutting medium and then a hard dressed steel edge ?
Depending on how long you want to spend on making a burnisher, it may actually be cheaper to buy a ready made Bergeon one.
Daniels has written in “Watchmaking” on how to make a burnisher, but I suspect it may take a number of tries before anyone can make a burnisher that is even close to a commercial Bergeon one. Take a look:
Thanks ifibrin.  I would still like to try though with a bit of tool making experimentation before i shell out over a hundred notes
There are also agate burnishers.  I would say its just as much about dressing the burnisher to a sharp edge, a square edge or an appropriate radius to suit the pivot being worked. As it is about the material. Steel has the added advantage of being dressed as needed and then hardened. Stones and jewelled files much more difficult to shape to a fine sharp edge.
The measurements for the Bergeon burnisher are 44x5x2 mm.
The measurements for the Vallorbe burnisher are 60x5x3 mm. (same for the file).
So the magnification in the images is approx. 12x (depending on your screen resolution)
Ah, so that's what the black stuff is! I continually wipe it off from the burnisher with a piece of Rodico as I go and then re-oil the pivot (still using Moebius 9010, but will eventually try with some lavender oil).
And that's why I decided to get it. There's so much to learn about servicing and repairing that once in a while it is worth the money not having to learn how to perfect the tools as well. If you're a pro that could be a different story but for an enthusiast like me buying a tool that's ready to use right out of the box makes a lot of sense.
Looking at the pictures I published of the Vallorbe and the Bergeon burnishers, it's obvious that the sharp edges are sharper/more straight on the Bergeon than on the Vallorbe. The sharp edge rests against the pivot shoulder and stabilizes the burnisher. Depending on how parallel you're able to hold and stroke the burnisher against the pivot shoulder, fewer vortex patterns are created on the shoulder. The Bergeon burnisher is doing a better job in this respect.
It doesn't take long at all (15-20 min?) What you do is place the pivot in a pivot bed on the Jacot tool being perhaps 2/100 mm smaller than the pivot, oil the pivot, burnish it, which doesn't require that many strokes (perhaps 20 to 40), and then wipe off the "black goo" on the burnisher, move the pivot to the next pivot bed being 2/100 mm smaller than the previous, and repeat the process until you reach the desired pivot diameter.
The good thing with the Jacot tool is that you don't have to worry (much) about the pressure of the burnisher or how many strokes you take on the pivot as the pivot bed protects the pivot once the pivot has reached the diameter of the pivot bed. What needs to be practised is moving the burnisher in long strokes in a "good tempo", which can be quite difficult to do when you're new. I believe @nickelsilvereither saw or experienced the teacher in watch school smack the fingers of the student doing too short strokes on the Jacot 😬. I practised on quite a few Vostok scrap train wheels before I didn't on the wheel that mattered to me (an Omega cal 268).
In the beginning, I was finding it difficult to hold the edge of the burnisher against the pivot shoulder. Repeatedly, the burnisher would slide up on the arbor and grind it down in no time. Yikes!
Ha-ha
Thanks!
A short, concise and excellent summary!
Yes, I wouldn't be one bit surprised if you're right about that. And yes, the Bergeon is IMO the way to go.
Edited by VWatchie
Ha-ha
Thanks!
It seems you are feeling better watchie, good. Thanks for the info. I may well buy one when I've had a little play, the price isn't too bad if the Bergeon has a good life span. If Nickelsilver wouldn't mind answering if the Bergeon ever needs to be restored from any wear ? What method do you use watchie to drive the jacot pulley ? A bow ? I have seen a retractable line being used which looks a bit easier also i was thinking of rigging up a small dc low rpm motor to free up both hands to help place and steady the burnisher.
Yes, nice long strokes of both burnisher and bow!
On the texture thing, just the last few days I was doing some special barrel arbors for a client. Drawing specs roulage on the diameters that contact the barrel as well as pivots (+-2 micron tolerance haha). Roulage is the same as Jacot but with a wheel rather than straight burnisher- and I have a roulage machine, basically an industrial Pivofix, with a variety of wheels. The drawing calls out 1.70mm pre-roulage, 1.69 +- 0.002mm post. With my fine wheel- and this is a motorized machine- I could get about 5 microns off but no more. Finish was mirror though. With a rougher wheel no problem to take off as much as I wanted; finish was equal to other high grade arbors I've seen, but not perfect mirror. Client is a maniac and will complain if not "perfect".
After a lot of messing around I went with rough wheel, then quick hit in the lathe with wood and polishing paste to give them the shininess they want. 15 pieces total; started with 25, ended with 17 hahaha.
But you can really hit microns with that machine  (and with a Jacot tool). Trick is measuring that. Pic is of an arbor in a Cary indicating micrometet set to 1.69mm. Graduations are microns.
Everything wears, so eventually, I guess it will need to be restored. Now, I've only used my Bergeon burnisher to work on perhaps about a bit less than 100 pivots (practice included), and I can't detect any wear whatsoever. Anyway, I'd be very interested to see @nickelsilver's reply as well (I think it's in already, as I type!)
I would like to have a bow but haven't found any yet. In the meantime, I've been using a retractable line (keyring yoyo). The ones having a line made of fabric seem to work the best.
Not sure, but I think you need to burnish the pivot in both directions, back and forth. Of course, a motor wouldn't do that, but perhaps it's a good idea, I wouldn't really know.
When I was in school we had a guest teacher (who became my main mentor) who had worked in Switzerland with the likes of Dufour and Derek Pratt. He was a  major fan of using a piece of elastic from the sewing shop attached to the back of the bench, with a bit of around 7-10lb test fishing line at the end to go around the pulley, with a simple split keyring at the end to drive the Jacot. Sounds pretty much like what VW has.
I like that method, but ended up needing to be more mobile with my Jacot work around the shop for a couple years and just got used to a bow. Either works great
👍 I think you are right burnishing in both directions may even out the surface better . Dragging the surface in one direction only may give the pivot a different finish. Now I'm wondering if the pivoting machines use both direction. I've found this one made by junghans.
https://www.ebay.co.uk/itm/115534361435?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=pLbdQDSpSL-&sssrc=2349624&ssuid=tBiLZaCfRb2&var=&widget_ver=artemis&media=COPY
Sorry not junghans, i cant find that one.
I just thought of a method of making a pivot burnisher which might be easier than the method described by de Carle.
I already have all the necessary tools. It's the same method for making the square section of a winding stem.
The rectangular/square rod can be clamped into a 4 jaw chuck on the lathe and the filing rest adjusted to just graze and roughen/smoothen the carbide rod. The filing rest would keep the surface of the metal flat.
A very rough diamond file should be able to gjve the correct grain texture of the rough end.
For the smooth end, probably a #1000 or higher diamond file would give a nice surface.
Wouldn’t you still have to temper the steel? Also, where do you get your steel from?
I get these from AliExpress. They are already prehardened.
SG$ 13.93 | 2MM CNC Lathe Super hard HSS Rectangular Cutting Tool Bits Bar 2mm x 16mm x 200mm High Speed Steel Boring Bar Fly Cutt
https://a.aliexpress.com/_mNIvkGk
    • In addition to the servicing guides do you have all of these supplemental information that Omega has? The reason I bring this up is the service guides might cover lubrication but things like epilam aren't always covered not mentally get to the newest generation of documents where it might actually mentions in the technical work normally it's in the supplemental guide? By mixing did you mean one drop of one oil mixed in with one drop of another oil to make a new lubrication or what exactly? Oh and I've attached a PDF the lubrication guide which by the way I do not follow sort of. Notice on the very bottom of the page a reference to? I just copy and paste something from the bottom The Synt-HP oils (9101, 9102, 9103, 9104) are preferentially in use for ruby bearings. For brass bearings, we recommend Microgliss D-4 or D-5. Notice for ruby bearings you can use the HP oils but if you're dealing with metal on metal you're not supposed to. Except this now conflicts with other aspects of Swatch group including Omega. Then the D series Are not synthetic so they have a shorter life? Then lubrication is such a bazaar subject with a very opinionated people and a considerable conflict with various documentation of depending upon who you look at. For instance you look at their recommendations for balance 9010 or 8000 which are both very light oils unless you're working in Arctic conditions. Oh then attaching another PDF. What makes this PDF interesting as far as I'm concerned is we have a company that actually grasps lubrication versus probably just about everybody else. Basically any time using 9010 are supposed to epilam everything including the balance staff pivots although finding that out as little bit harder. Typically anytime using HP oils you're supposed to be epilam ing as it has a habit of migrating without epilam. But personal experience has been  9020 will stay in place although that's just my personal observation for what it's worth. Then we have this silly company the oil of choice 9020. So if you look they lubricate the entire watch with only three lubricants they have a grease I would you something different I like 9504 they have 9020 I love 9020 and they have the grease for the escapement oh and you're not mistaken that using 9020 on the balance pivots other than me as far as I had tell they're the only ones. As I'm typically not working on little tiny watches my lubrication of choice is 9020 for the balance pivots for the gear train for the center wheel I usually use HP 1300 but I can probably use 9020 there I am suspicious when at the bottom of lubrication chart the reference to not to use HP lubricants on metal on metal we don't get an answer of why other then I believe you need epilam. This is where a lot of companies use the HP 1300 on the key less and they epilam the entire T list to keep it from spreading all over the universe.   tableEN lubrication watches.pdf PIAGET 12p.pdf
    • A magnet attracts this lost one, big strong magnets.
    • Those bath are are not the same as an ultrasonic machine that we know. They only shake....and do not produce the cavitation bubbles that clean surfaces
    • The main reason it's advantageous to start with a pocket watch movement is that the parts are slightly larger and therefore easier to handle. You'll quickly discover that watch movement components are much smaller and more challenging to work with than you probably imagine—especially if you're used to looking at all the macro photos on WRT. There used to be plenty of Unitas 6497 and 6498 movements in inexpensive pocket watches on eBay. Try searching for "17 jewels Swiss pocket watch." If you see a separate sub-second dial on the watch face, there's a good chance it's a Unitas movement. Once you look at a photo of the movement itself, it's usually easy to confirm—these are often engraved with names like "Arnex" or "Nastrix" and are of high quality. The image above comes from a current listing on eBay. The seller is asking $60 but is open to offers. Don’t buy unless there's a clear photo of the movement! Another advantage is that most of these movements have Incabloc shock protection, which is relatively easy to work with when starting. Both of your watches use Incabloc, too! (https://www.ebay.com/itm/146553701302) Here's a link to CousinsUK.com, where they sell an excellent Chinese clone of these Unitas movements with Incabloc. I find working with an original Swiss Unitas (now ETA) more enjoyable: https://www.cousinsuk.com/product/3-hands-seagull?code=CHI3600M Another great thing is that there’s a huge selection of cases, hands, and dials for these movements on eBay—perfect if you’d like to build your own watch later on. Good luck!
    • I've done nickel plating in the past but using nickel solution and always plate with copper first as nickel bonds better to it and it removes any blemishes.
