Old Pocket Watch ID
wudce
Hello Folks! It's been sometime since I last posted anything had to take a long break from watch making. Was given this old pocket watch and I was surprised that it wound and run at all since after taking a closes look at it and seeing how gunk up it was. So far I not ID it 100% but when I first seen it was thinking it was a old Waltham. I did some digging but did not find much on Langendorf watches other than Langendorf is the name of a town in Switzerland and that company was the biggest maker of Swiss movements in its day. So what I found on the watch was Steward 15 jewels Langendorf W CO. Swiss on the motion side and on Keyless side 833930 which would be a  serial number I'm guessing  but so far not no sure. As always thanks for any help.
Cheer! Paul
Hi Paul,
It would help to know the diameter. There are approximately 90 variations of Langendorf calibers shown on Dr. Ranfft's web site. Knowing the diameter and any numbers would help narrow the search. You should be able to match both your dial side and train side images to one of the watch movements shown there. Type "Langendorf" into the search box.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&2&2uswk
Edited by grsnovi
forgot to add link to ranfft
I have look there but did not see this calibers unless I miss it and that page only listed one open face watch and that's not this one also don't see any with this type of keyless works. Anyways  this is a open face pocket watch and the OD is 39 mm and the only number found was what was in my first post which is 833930 also this has the split winding stem. I did find one like it case and dial looks about the same and the motion side looks about right bid says 6J but that's not helping much since there no 6J showing on the  ranfft site.
https://www.ebay.com/itm/193775885740?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=193775885740&targetid=1263433206854&device=c&mktype=pla&googleloc=9010006&poi=&campaignid=16190447015&mkgroupid=128435277530&rlsatarget=pla-1263433206854&abcId=9300820&merchantid=108984430&gclid=Cj0KCQjwguGYBhDRARIsAHgRm49iBG1v8kjjLFw078lcAsaf7x_u-nBtP4MH32nhfWcRvKNqQB-ikRAaAl4CEALw_wcB
Edited by wudce
5 hours ago, watchweasol said:
Have you had a look on the "pocketwatchdatabase.com" site. If you have a maker and serial number you should be able with luck , to ID the watch.
the problem with the pocketwatch database is it's based on parts catalogs. This means typically the watches are American the company had to be big enough to actually have a parts catalog.
4 hours ago, grsnovi said:
.just not which. I wonder if sending your images to Dr. Ranfft would help him? He must have "holes" in his database.
I don't know about Dr. Ranfft  website but I know the pocketwatch database I think you can submit pictures. The problem is there are so many unidentified watches out there
Moving to correct sub-forum.
Why is this happening?
Please don't be offended - from time to time, in an attempt to keep WRT organized, we need to move threads to another area more suited to the subject of that thread. Members can help the forum staff by checking for a suitable sub-forum before posting as this will help to reduce their admin workload.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
