National Electric Watch Cleaning Machine
Thanks cees, it looks veey much like the same design made by Wiru, also has the tap set to match, starting at 0.4mm. -
I've inherited a pendulum clock with a broken pallet (please see photo) & I'd be grateful for advice as to whether, & if so, how a repair could be effected. As adhesive - even if it were strong/durable enough - would slightly alter the pallet geometry, I was wondering if a suitably shaped brace could be spot welded to each side edge to effect a connection but could the pallet be cast iron & therefore likely to fracture?. Also, what terms should I use (e.g. descriptive of the type of pallet) in searching for a replacement online?
Hey there, I'm a couple years late to lunch here but I've found the same pattern, along with some markings, on a non-original Omega Geneve 613 dial. Same hearts/clovers, but I'm not sure what the rest of the numbers and markings mean here.
Here is the clearest possible example demonstrating how your fine Gyromatic works https://ciechanow.ski/mechanical-watch/ Welcome to the forum
I expect you should be able to wind it by hand with the crown and then when wearing it the 'gyromatic' part keeps it topped up, for want of a better phrase.
