Hello everyone, I'm looking to purchase a polishing tool and wanted to ask for your opinion.
I am torn between a handheld Dremel or a Deluxe bench top. I assume that with time, I will probably buy both, but due to current apartments constraints and pending negotiations with my wife, I am more leaning towards the Dremel as it is just easier to store away. One reason why I'm also leaning towards the Dremel is that I will soon be restoring a lathe and being able to polish some parts by hand should give me more flexibility to work on non flat surfaces that may be a bit harder to reach (also I cannot stick the whole lathe under the desk top tool 😅)
I guess now that I wrote it down, I pretty much have my answer, but maybe there are things that I am failing to consider?
Thank you
Bench top will always be better for larger surfaces (like a watch case). But space is an issue in my mancave, so I only have a dremel and get acceptable results.
I'll probably get a bench top one at some point though
The  Dremel you linked is 300% overpriced. You can buy a no name rotary tool with same or better quality, full accessories, for less than one half. If possible get an accessory to fix it on a small vise (Proxxon has it) or the like, for light polishing it will do almost the same work than a bench one.
Hi I have one the same as Frankie's and have had no problems, I also have a little hand held (Maplins) tool wich  has  also has worked well for a good number of years. As jdm said  Dremel  way over priced.
Thank you
Eyup matey. I use a cheap cordless dremmel type tool by the make name of parkside, supposedly German from a supermarket here in the Uk called Lidl. They also sold a bench mounted jig to hold it so it has the use of hand held and bench mounted. Variable speed and even though it is battery run it does last for hours between charges. It takes different  sized collets that hold all manner of accessories, the 25mm felf buffing wheels are perfect for polishing cases. Both the tool and jig came to £20 .
2 hours ago, frankiethebear2002 said:
Hi folks, this is the one that I use for hand polishing.  I also trap it down to a jig and use it as a static one too.  Its not bad and pretty effective.
https://www.vonhaus.com/vh_en/135w-multi-tool-40pc-accessory-set
Hope this is of some use.
Frankie
Vonhaus gear is ok. I have a big cordless stapler which is great for tacking plywood and a slotting tool for joining worktops also not bad.
For hand motor I have a basic level Proxxon that's seen hourly daily use for 16 years, still running strong. Dremel doesn't hold a candle to it (owned those too). The boutique  watchmaker Christophe Claret issues each watchmaker in his employ with a Proxxon, they're 10x cheaper than the real hand motors and they just work. A high end hand motor can cost from 1.5k to almost sky the limit.
A bench polishing machine is a very different animal and there are plenty of YT vids of serious case restorers showing how they build back up a case with laser or brazing and then bring it back to original shape. Back in the day you'd lean in and get "everything shiny". Now most vintage watch owners opt out of case polishing .
But on your own watch, a combination of perhaps filing and abrasive paper finishing with a hand motor polish can look very good.
It may be to do with autism and all round Neurofunkiness, but I hate seeing tatty cases and dials.  i get it that most folk seem to like the effect of age showing as it adds character and gives a feeling of having had a life, but if its mine, it gets the shiny.  Just one of my many quirks, but I like to see it as its was made and intended to be.  I understand that sometimes gold is used for more than aesthetic reasons, but its a very lustrous material and I think its lustre should be celebrated and not covered up by years of sweaty fingerprints and sebum.  Tarnished or dirty gold just "gies me the wullies".
Frankie
I've had a Parkside wired one since Moses was a lad.  The actual tool is connected to a plug in power supply by a three pronged micro plug, pretty weird set up, but I've had it for years and still works flawlessly.  Wifey can always tell when I've been polishing something as the inside of the shed looks like its been roughcasted.
One thing I don't like about the von haus is the collets, i'd rather have a jacobs chuck type holder.  As far as I'm aware they are readily available.  I do have a special birthday on Saturday, so.....
One thing that I really do like is the extension cable.  It lets you keep everything else out of the way and lets you concentrate on the job in hand.  Quite a bit of thought went into that cheap orange lump of very useful plastic.
Frankie
Here is the cordless dremmel type and also a variable speed bench  grinder with a polishing mop a grinding wheel and scotchpad wheel also a parkside from Lidl. They are very cheap but actually have a 3 year guarantee on them so they cant be too bad.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
    • Could you fit a sapphire crystal? My 'daily wearer' Breitling Aerospace is 22 years old and there isn't a mark on the sapphire crystal.
    • Oh that's neat. I typically use a thin strap of rodico laid over the pallet fork to affix it to the upper plate but it can be hard to retrieve sometimes. And as I did more research, I may have just found your own earlier explanation: https://learntimeonline.com/forums/topic/potence-clip-for-full-plate-p-ws/
