Next Video - Breitling Bentley
1 hr 55 minutes, that a whopper  :startle: . Will it be in parts or just a single upload ?
I will have to split it up. Could be eight 15 minute episodes or six 20 minute episodes... any thoughts?
I am interested if Mark had issues with the hands. The last Brietling I worked on (Avenger) the hands where nightmare to remove & fit.
They actually came off fine this time, but I have had trouble in the past with others.
It's not a problem to have it in few episodes will be much easier to upload, a playlist will be helpful if we want to watch it continuous.
If you happen to have youtube monetization enable it is good to have it in few segments since the advertising revenue will depend on the number of video you upload.
It's been a few weeks since I uploaded a video, I have been working on a monster. Just finished editing and it is almost 2 hours long. Just the voiceover to do now.
Hopping in anticipation. Any news of a release date. Only a week or two until the Edinburgh International Film Festival.   :)
Hopping in anticipation. Any news of a release date. Only a week or two until the Edinburgh International [/size]Film Festival. :)[/size]
That would be good, it's just down the road from me! :)
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out.
    • Yes I understand that. What I’m asking is, after the hands have been fitted, it’s been checked that the hands do not touch etc. then I need to remove the stem to fit the movement in the case. I have the push type, I need to turn it upside down and push the setting lever post and pull the stem out. But of course the dial and hands are in place and I have a glossy dial with lume dots and I do not want to cause any damage while it’s upside down pushing on the post of the setting lever.
    • You have answered your own question. You just push the setting lever nipple in or if its the screw in type unscrew it a little. You should always remove any hands and the dial before putting it in your movement holder.
    • Did the old battery leak and damaged the circuit board? Can you post some photos of where the buttons make contact on the circuit board.  Try cleaning the gold fingers on the board with alcohol and also the conductive rubber strips behind the LCD display panel.
    • How do you safely remove the stem after fitting hands? I’m talking about the push type setting lever you need to push to release the stem. Some dials can be intricate, glossy finish, lume dots etc. and placing it in the movement holder can be quite risky and cause damage.
