Hello everyone.  I am retired (from being in the software business for 40 years) and started to study watch repair in the past few months as a hobby.  I found it both relaxing and focusing.  I have traditionally also been a woodworker and general do-it-all but watch repair and restoration is sooooo much cleaner and does not require a huge space, big machinery, or overalls 🙂 I started with 2 pocket watches that belonged to my grandfather.  Neither worked.  So lots to do on those.
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
As you progress buying tools and material you will find you never have enough space .
Yes, I thought space wouldn't be a problem, but it has started to become one already.  I naively thought small tools, small space,
Thanks for the intro, welcome to the WRT forum! I'm also relatively new and I'm in the middle of my first service of an Elgin Grade 313 movement.
I'm also retired and was also in the CAD/CAM s/w business for 20+ years.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
