Hello from Hong Kong
FM2
5 hours ago, Nucejoe said:
Hi Frankie, welcome to WRT forum.
Will you also tell  about your tech/ watchrepair background and ambition in horology.
Regards
I have just finished a foundation course last year and will take watchrepair as a hobby.
Frankie
On 4/5/2022 at 3:22 AM, grsnovi said:
Thanks for the intro Frankie Lee, welcome to the WRT forum! I'm also relatively new and I'm in the middle of my first service of an Elgin Grade 313 movement.
Are you planning to do work on watches?
Hello grsnovi, I am working on my friend's fake Franck Muller but damaged the incabloc spring, need to get replacement.😅
10 hours ago, FM2 said:
...fake Franck Muller but damaged the incabloc spring, need to get replacement.😅
I guess that's one of the downsides to "fakes" - they're not built using the same quality parts as the real thing. I'm too new at this to tell you much about finding one-off parts. Most professionals seem to have hundreds of watches they use for parts and/or bags of spare screws and the like. Your best bet might be to find a movement that you can cannibalize.
    • Hi @Roll1ex, welcome to WRT. Is there a big second hand watch market in Mumbai? I seem to see a lot of used watches and clocks on eBay coming from Mumbai.  I used to buy a watch every month from Mumbai on eBay. My mentor told me it was the best way to learn watch repair, by fixing everything that's not right.
    • Here is another option, if you have the patience to sort through the parts you usually find 50-100 screws as well as some other cool stuff. Most times I get an order from these guys I get a 250g box, takes a few days, but end up with hundreds of spares and all you need is for one of them to be useful and it pays for itself. Also helps hone your tweezer skills!
    • As Hector said they have too much  tension, that tension is also fixed and not easy to control. Conventional tweezers have infinitely variable grip provided by us.
    • Thank you and i appreciate that, it looks very different    Thank you sir but i think there is a little problem according to that reading it's because it is far different to the other move that i serviced, i will atouched the photo. They are different movements but this one is 7s26b movement and they are also different in shape when it comes to the ballance assmebly. Thanks also for the concerned i appreciate that.
    • Donor movement showed up, so I stole the bridge screw from it. Which made me sad, because it's in such nice shape! It seems a shame. Maybe I'll find a use for it one of these days. Unfortunately, the stem is for a different style of case and is much too short. Fortunately, I ordered a brand new stem from McCaw Company. Unfortunately, the crown on the donor movement is thoroughly stripped out (it unscrewed in a shower of brass) so i just put the old stem back in for now until I source a new crown. As you can see, it's just a little too long for this case. Overall I'm super pleased. I didn't think I'd like the bracelet, and even that is growing on me.   Anyone have a favorite crown assortment?
