I have recently started to take apart the clone 6497 from a watch which had stopped winding effectively. I removed the mainspring from the barrel but it was fractured. Ive tried measuring it with verniers but cant seem to find a mainspring for it on cousins. Does anyone have an idea of the spring required, or is it better just to buy a new unitas complete barrel with arbor and spring? third option would be to buy a new clone but this seems bonkers in terms of cost. Any suggestions would be gladly received as im desparate to put it back together and isee if i can make it run...
TIA
drD
If you post the inner barrel diameter, we can suggest an appropriate strength ans length. For height you can measure the old spring.
Frank
thanks guys, i got it at approx 630 long, 1.44  height, 1.0 thick barrel inside 14.4
is the length not that important?
For 14.4 mm barrel a spring 0.17 - 430 ... 470 (thickness / length) will be ok.
not that 🙂
Frank
  • Haha 2
Ha, this is very interesting! So, by looking at the measurements and then comparing it to other springs we might find a fully working alternative costing almost 70 % less! Never thought of that! I'd guess the £23.35 simply reflects that there are tons of Unitas 6497/98 movements that people still service.
Yes, price calculation is interesting.
Just a minute ago I looked for jewels 140-50 on a wholesaler's site:
140-48 $14
140-50 $28
140-52 $14
140-54 $14
so have loaded the spring into the barrel. it looked like it could only go one way to latch into the abor - does this look right becasue i cant get it to wind up?? Noob idiot question im sure.
That's the correct orientation, but the inner coil looks too large for the arbor. Did you buy the longer spring? It's tricky to close the inner coil, ideally you would have pliers with  concave and convex faces opposing which can reduce the radius of the curve. If you try, it's good to heat the tool in an alcohol flame until almost too hot to handle, it doesn't affect the heat treatment of the spring but does facilitate the bending process. Nivaflex is resistant to plastic deformation- it tends to go straight to "breakage".
Most likely the innermost coil is a bit too large to engage the hook. See if you can close it a bit, pressing gently and not near the hole which has less material. Too much squeezing and it will break, be advised.
Edit - above you have it, master Nickelsiver always ahead, better, and with more tricks. I never want to play cards with him.
yes bought the larger spring, i bought 2 incase i broke one so i guess ill have a go at bending it.. Thanks for the advice.
On 3/10/2022 at 12:58 AM, drD said:
clone 6497
Then is it really a 6497? The reason I ask is there's at least two of them, there is the normal one we think of that sometimes is called a 6497-1 this runs at 18,000 beats per hour. Then there is the more common Chinese clone which is known as a 6497-2 this runs at 21,600. The reason for asking is there is quite a bit difference between the two of them a lot a similarity but a lot of differences. In particular one difference is the mainspring both mainsprings are different both arbors are different and both barrels are different. Then somewhat unhelpful answer is from the bestfit website I copied and pasted the information below as you can see both mainsprings are different.  So the reason you might be having some issues is if you're getting the wrong mainspring.
ETA 6497-2  770/274  771/6497-2 GENUINE MAINSPRING
ETA 6497-1  770/288  770/ETA6497-1 GENUINE ETA MAINSPRING
7 minutes ago, nickelsilver said:
Yes, distributed along the whole curve right up to where the next coil starts.
If one had a tool with a suitable / special collet, do you think that would work?
@JohnR725 thanks for the info, id assumed it was a 6497 and it follows the 6497 unitas cailber on a diagram of parts and assembly. ill have a look at the mainsprings you noted also . Thanks
Technically they both 6497's They just have a – with another number. For instance if you look at the two PDFs that I have attached other than the cover page they look identical. On the cover page we find out there's a different frequency and the running time of each is different. Otherwise the documents are identical. Then unhelpful is any information related to mainsprings as apparently they very. Even if you go back to the older documentation it's not entirely clear whether they have separate mainsprings are not.
ETA CT_6497-2_FDE_482448_13.pdf ETA CT_6497-1_FDE_482160_11.pdf
thanks for the above info - they both look the same dont they. as a chinese clone i wonder which ive got. tried bending the mainspring but could get it tighter until i bent it! Then i fractured it. will have another go with the second. then its a toss up between buying another cheap calibre or the more expensive mainspring, my main consern it that that spring may also not lock into the abor.
The easiest way to tell would be to put it on the timing machine and see the frequency. But even without that I suspect most if not all the clones at least currently will be 6497-2 movements
Interesting about heating up suppliers? My experience has been with any of the modern White Springs if you try to bend it it breaks. The person I work with tried something which does work which is taking a piece of peg would in the center and then you squeeze the peg what keeps you from bending it too much and I've had great success handing it to my boss and having him do it because of I try to bend it it will break. So with the peg with air and you slowly manipulating it you don't put enough of a curvature to break the thing I'll have to try the hot plier method
Seeing as how you have your barrel apart what you measure the inside diameter of the barrel and the outer diameter of the arbor that goes on the mainspring. I left myself a Post-it note we have 6497 parts that work all measure one of those these I'm curious if there's an actual difference like the parts list or at least some of them indicate. Because my guess is in order to get a longer running time there's more mainspring in their they had to shrink something or make the barrel slightly bigger or maybe they did both. Even though visually they look identical at least on the plans
great idea. ill try that with the second spring - would you recommend doing this whilst its still in its packing ring or once its in the barrel? once the spring is free o never seem to be able to free hand coil it back, and the cost of the spring winders is eye watering!
ill measure it and give the internal dimensions
Trying to do it in the barrel would be at least in my experience different costs if not impossible. I can usually do it with the American mainsprings or the older blued steel spring is as their soft in the center. Which gives you the only option of still doing it in the ring which is nice can give access to both sides. Ideally you should have mainspring winders
As I have a broken 6497 running at 21,600 I assume that means it's a 6497-2 equivalent. Broken because I found winding it much easier to do than a standard  6497 and then fell off mysteriously. Yes you could see it was welded into spots and they were very security came off. But that didn't give the opportunity to take the work where we have brand-new 6497 parts to compare.
You can see in the photograph the clone is on the left and the standard spring is on the right visually they're just a little bit different in size the arbor for the clone is 3.65 mm in diameter the standard is 4.10.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
