Advice Wanted :)
Hi folks, i was going through my personal collection when i came across one of my favourites which i had not seen in quite some time. Sadly the battery/capacitor is kaput and since i don't touch quartz watches i was wondering if any of you fine folks know of a reputable watchmaker within the UK who could give her a oil change  , so to speak  :D
Actually whilst searching my collection i found a whole bunch of ETA movements new and old that i had long forgotten, which was a bonus, yay !
1993 Junghans Radio Controlled Mega Solar
I can not adjust the time ( cant find manual anywhere for this model :( ) and even after a good charge she just splutters with hands all jittery.
I don't even know why this watch is such a favourite but i does luv her so :)
Ps I hope all you fine folk are doing well :)
In direct sunlight it does spring to life but i can not make heads nor tails to adjust it :(  It should adjust to correct time automatically, my other Junghans Mega which was sat with it has sprung to life and set it self exactly correct time.
This is why i love mechanical watches, why oh why did i fall in love with these German quartz's lol
Could it require a good long charge in daylight ?? ( i only gave it 5 minutes )
I would leave it for an hour or two and see if it sorts itself out. I know my radio controlled clock in the kitchen takes a while to correct itself when I change the battery.
Never seen one before. Its going to pee down all day tomorrow in Herts, have you got a daylight desk lamp or a UV lamp? would the toothbrush charger trick work on one of those it must have a coil...... not much help really am I? :D
My desk lamp is very bright ( daylight LED 80+ ) but not enough or maybe the right kind of light to kick it into gear. Whilst i was out in the garden earlier it had plenty of energy so i assume it must need sunlight rather than synthetic light sources. I had a Casio solar powered watch that had same issue until i left it in sun all day, it ran fine after that. Please please please just need a charge up oh god of watches   :bow:
Well i hope it don't pee down :( i only need a few hours of sunbeams to find out....
Well i have left the watch out in daylight all day and no change. I decided to open her up and see the type of battery/capacitor it takes and find that it is soldered in place :(
The battery itself is a cheap VL2020 but it is soldered to the circuit and also the battery is hard soldered to the contact arms, see below
After 20 years service i think the poor battery has had it, but how on earth am i gonna get this changed ??
Any ideas or help will be greatly appreciated
If you "google VL2020 with solder tags" you get a number of options to buy from about £3 upwards.
Then you need a soldering iron with a fine tip. Just un-solder the old one, trim and bend the tags on the new one to fit, and then solder it in (check the polarity). You may find that some de-soldering braid or a de-soldering pump helps although I would be inclined to just lift the tag clear of the board using tweezers as soon as the solder melts.
It shouldn't be a difficult job if you are reasonably practised with a soldering iron. If you're new to electrical soldering then you might want to have a play around with something that doesn't matter first, then try to put as little heat into the job as you can get away with when you do the battery change.
Thanks Marc, i have actually found an exact replacement that just requires a small modification to one of the legs. I have a soldering iron, though i have not soldered anything for a good while i do know not to allow heat build up on such sensitive areas. I think with just a little bit of care i can do a straight swap :)
Still the battery did well for such a long time :)
Well today i finally got the new capacitor and without much fuss fitted it into the mega. She came back to life with no problem at all.....until.......i find the minute hand had come loose in storage and was blocked by the hour hand.
Now i know why the time would never set correctly as the minute hand was loose, but now im stuck as to how i set the correct time without a stem. The watch is supposed to automatically sync with radio signal and set correct time but every time i try to auto sync it displays wrong time ( as of course it will ). The time is out by around +1hr+20min ( ish ) each sync.
So am i right in thinking i have to auto sync first then refit hands to correct time positions ?
( this is why i stay away from quartz/electric watches lol )
Just to conclude i have now finished the watch and it is now running as it once was. The hands were loose so i have carefully refitted them and the watch is now running at the correct time. Hopefully it will last another 15 years :D
    • I kind of think the same, the surface under the oil is the same as the surface around the oil. Can epilame both repel and attract , that doesn't quite make sense in simple terms, but is it more complicated than that.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
