Hello I’m a newbie at watch repair
I have fascinated by watches since I was a kid . I’m having difficulty remembering how to put a movement back together after taking apart for  a cleaning or replacing parts does anyone have any tricks to remember the order to reassemble a wrist watch movement
any help would be greatly appreciated
When I started I used a tray with multiple compartments.
I grouped the parts in functions of the watch.
So train with bridge and screws in one, Barrel with bridge and screws in an other, date bits in the next and so on.
Take a good picture when it is all in bits of the tray for putting them back in the same compartments after cleaning.
Now I just know where the bits go and do not have to do that anymore but the system worked fine for me.
Welcome to WRT forum.
Try online searching for documents on the caliber your working on, data sheet, schematic diagrams etc.
Taking piictures at every stage of disassembly is useful.
Beside the mentioned labelled tray, and of course taking pictures at all steps, I think the most important is that one fully understands the ins and out of the function of each single part and screw, as in why each is shaped and sized as it is, and how interacts with the next part.
That is the only way that will allow you to put it back if parts gets mixed, pictures erased, and exploded diagrams are set away for you to test yourself. Otherwise you will be more similar to a trained assembly worker than a watchmaker.
Welcome to the forum.. 🙂
Go online na hunt for the tech data sheet for the calibre of movement that you are working on.
Lots of guys on here will be able to assist as well.
Also, check if YouTube has any videos for the calibre that you are working on.
I'm also thinking of just leaving a video camera on to record the entire disassembly of an unfamiliar calibre.
But after awhile, you'll get the hang of things and be able to identify every part even if you jumble everything into the cleaning basket.
    • Depends what sizes of watches you mostly service . If you were to say pocket watches then you might benefit by wholly replacing the 9010 for 9020. As a rough guide hp500 is twice the viscosity of 9020 which is twice the viscosity of 9010 at 20°c.  So hp500 would give you a more mid-range oil between thin 9010 and HP1300, but as it happens hp750 is more mid- range than hp500, but is that more or less useful when oiling a train of wheels. After the barrel arbor the jump down in pivot size is around half, then after the centre wheel maybe more than half until the escapement. And pivot size isn't especially a deciding factor, as the torque and speed of a pivot would be more relevant when thinking about which oil to choose. So 750 might only be useful on a centre wheel and nothing else, and 500 might be better than 1300 for oiling the centre wheel but still comprises the rest of the train, where 9020 would be ok for the train but too thin for the centre wheel, leaving only 1300 for the oiling of it. You see the problem we're having here. What can be ok for one thing is less ok for another in a different way, damping down power compared to oil spread.  Maybe mixing a drop from two opposite range viscosity synthetic oils will give you some approximate thickness of an in-between . You want a short answer now ?  I tnink I'd go with the 9020. Now be prepared for a whole host of different answers. Then to go with this, watch manufacturers change their minds about which oils to use more times than actresses change their knickers.
    • So, working on watches and your karma at the same time: win-win situation!
    • @SteveF ,  Go on to Dr ranfft website,  Enter keywords Omega 26.5T3  ranfft .  There Dr ranfft  has listed all related calibers to this family, all which beat the same frequency,  any balance complete of this family fit your watch. This would only expenad your choice of balance complete.  Recolleting your hairspring is easy, but matching it with a balance of the family is challanging. Regs
    • Yes, it looks much better, but at this point the main thing is to make the spring in one plain. so picture from side will show this better. Now it is seen that #1 bending is needed, which is normal.
