Flats on a bearing surface
Ive not encountered this before and wanted to ask if it is more common than I think it is?
This is a Molniya pocket watch from '59.  Its a beautiful and purposely thin movement.
In the photo is the fourth wheel and needs the seconds arbor repivoted. The glare on the bearing surface that rides in the jewel is a flat and there is one that aligns with every valley in the pinion.
Its polished so i imagine its factory and may be done to reduce friction? Just guessing here. Anyone else have experience with this?
That is because to cut correctly the leaves of the pinion to the given depth the cutter removes also a bit of material in there. Then it's polished so the resulting edges don't interfere with the jewel.
2 hours ago, HectorLooi said:
The pivot appears very short. Is the pivot broken?
So it is, as the OP had mentioned. I never heard of a seconds hand pivot being refitted to a pinion, and I'm a bit skeptical about it's practical feasibility.
As JDM said, those marks are a remnant from cutting the pinion leaves. As that surface is nonfunctional, it's just a cosmetic issue.
As for repivoting a 4th wheel, it's a common job. It's best to make a stepped plug, so that there is a bit of a shoulder at the pivot/pinion interface so that the pivot doesn't pull out when removing the seconds hand. Just a quick sketch below to illustrate. In practice, I'll drill oversize, fit the oversize plug, then turn down the pivot and burnish to finish. When all done the repair is invisible.
You are totally right, I am mistaken in what I was thinking was the bearing surface. Noob mistake.
11 hours ago, nickelsilver said:
As JDM said, those marks are a remnant from cutting e a stepped plug, so that there is a bit of a shoulder at the pivot/pinion interface so that the pivot doesn't pull out when removing the seconds hand. Just a quick sketch below to illustrate. In practice, I'll drill oversize, fit the oversize plug, then turn down the pivot and burnish to finish. When all done the repair is invisible.
Thank you for your "Quick Sketch" Mine would have been unintelligible by comparison. I will do the repair as you've illustrated. I was concerned about how small the arbor was going to be at first. Your repair is the superior method
    • Hello and welcome from Leeds,England.  Ask away.
    • What cutter are you using can you video the action
    • if you're trying to keep track of conversations scattered all over the message board emails are an absolute must.   looking at the bell icon on the top of the page versus the emails today it looks like I got the correct amount of emails. So making some minor change based on the one of the images up above I started getting notifications again. But at times I still have a suspicion that something isn't quite right. I have some feeling that the message board may delay sending emails until something so seems to be a long delay between when you get your emails just a weird feeling things aren't quite right oh  and then even though I do seem to be getting emails I no longer get notifications of personal messages I don't find that out until I arrived at the message board where I'm pretty sure I used to get notifications of those two. So something is definitely changed on the message board. then for everyone not getting emails you do want to check your spam folder. I have found that sometimes were open up an email the system I use warns me that it thinks the email is evil and bad and I have no idea why he thinks some of the emails are and some are not. But this is actually the program I use not the email system which also has a mind of its own as to what it considers spam so you should always check your spam folder.
