Hobby Watch Maker
Hi Sendikumar, if I remember well, the minute hand is inserted in the gap between the hour wheel and the cannon pinion or rather on the cannon pinion (I haven't worked on one of those for some time now. It depends on the hands you are getting and yes, it looks a little high but it might be the way the picture was taken. Just get a dial as Geo suggested and check that you have enough of the hour wheel out and clearance for the hour and minute hands.
Also, don't cut the stem until the very end when you are ready to give the watch as finished: that's the last thing you would do. Also, I wouldn't cut the hour wheel because of many factors, one that come to mind is finish and another is "even", if you screw up you will be in a real fix to fit the hour hand properly if at all. Remember the hands tool stops on the rim of the hour wheel (on top). That surface should be even or the hand will be twisted and you will have to adjust by sight...it still can be done but not very professional. I 'd rather get a shorter wheel or a longer canon pinion...they are all the same for that movement regardless of country of origin.
Good luck with your project!
Cheers,
Bob
I am bit busy with my work , with computers creating software, in tight deadlines. However I ordered dial and it will be ready in couple of weeks time will start again.
For sure I will post lot of questions and queries
Sent from my XT1068 using Tapatalk
Ah Sendil
Work - that horrible four letter word that stops the fun in the pursuit of income.  I well remember that from pre-retirement times before my hair turned grey and then fell out.
Hope your ventures are successful and I look forward to the next posting.
Cheers,
Vic
I'm there now Vich, glad you read my future! Four more years....I can't wait!
Cheers,
Bob
  • 10 months later...
    • H Watch Repairers—is there is a ‘standard format’ for the service marks or codes lightly engraved inside cases of pocket watches or wristwatches?   Sometimes I can see there might be a reference to year/ month but other times am confused. I’ve included an image of the rear of a 1951 Hamilton 992B Railroad pocket watch as an example. Thank you for all information you can give, Mike
    • Hi to Blackminou29–am a collector/ caretaker—good luck to you following your repair course—with hindsight I wish I’d pursued a career in both watchmaker/ jeweler fields—good luck with whatever career passion you engage.   Thank you Watchweasol for posting the amazing TZIllustratedGlossary! Best wishes, Mike
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
