Hello,
I'm just a beginner, too, and I'm verry interested in mechanical watches at all. I'm a physicist and engineer and work in a university of applied sciences in germany.
Because I get a new watch from "Mühle Glashütte", there is a high motivation for me to do the service by my self. So obviously there will be  5 years time (following the manual) to learn how to do that until the first service will be necessary (please excuse my poor englisch - it's not my highest qualification 😉). I will did my first practice on a Seiko watch with a 7S26C movement. And I dissassembled it following the youtube videos, clean it and put it together again two times, and it's still alive 😀.  But it has some problems I'm not able to solve - I will post in a an other threat. I do al lot of 3D-printing, so I developed a couple of tools such as a movement holder, a wheel centerer and a hand placer by my self and produce it by my 3D-printer - and all works fine 😄
Thats all from me for this time and I'm verry glad to be here.
Many thanks and best regards from good old Germany
Tobi
Welcome.
I like the sound of the 3D printing, you'll have to post some pics of the tools and movement holders you have made.
I quite like the look of the Mühle Glashütte 29 ER Day/Date on the metal strap and the chronograph with the white dial.  I do like a red second hand on a watch too.
Many thanks! 😀
Yes, your are right, my "Mühle" is a 29er, too . Because I'm not at home, I can only post the rendered views at this time. You can see the hand placer an some tiny tools such as the wheel centerer, the movement holder but also an oil bowl and - I don't know the correct name is - a barrel assebler. Some of them are made out of CFK-PLA such as the lower part of the barrel assebler, the movement holder and the hand placer. To get a fine surface I presst some hot ball-bearing balls in the pits of the oil bowl. All axes are made from 6mm-steel and the threaded rods are M6x1🙂
best regards
Tobi
Herzlich willkommen, herr Tobi.  I have lived in the US all my life, but my family can here from München and surrounding cities. Ich spreche eine kleine Deutsch, aber es ist lange her, dass ich diese Sprache viel gesprochen habe.  I need to practice more.
Enjoy our forum.  It has many valuable resources.  And there are experts here who can help with a wide range of difficulties.  Have fun!
Hello,
thanks for the nice greetings. I'm glad to meet you all here and I'm verry enthusiastic to learn a lot here in this community 😀
5 hours ago, UhrTobi said:
Many thanks! 😀
best regards
Tobi
Very impressive
Hey UhrTobi!
Great to see your 3D printed stuff.  Certainly interested in your watch-related creations.  I am a big 3D guy myself.  I do my designs in FreeCAD (because it is free!!).
BTW...your English is better than my German!!!  I used to teach a short course in Berlin (twice a year) back in the '80s.  Learned enough to get around but have since lost it.
Nice work.
Quote
Thats nice - thank you, I give my verry best 😉.
Quote
Ok, here it is 🙂 https://www.thingiverse.com/thing:5196938
Joining a German forum refreshes all you think you have lost.
On 1/12/2022 at 4:41 AM, UhrTobi said:
Ok, here it is
Nice.  Intrigued by this comment: "All threads must be cut and all holes must be drilled using alcohol, otherwhise the PLA stick to the cutter tool!"  I know that drilling pla is tricky because the friction heats up the bit and melts the PLA.  Is alcohol (IPA) the solution?
Here is a thing I made to stabilize a balance cock while working on it.  I posted about it in the tools section. It is just a puck with a bunch of holes in it.
Guten Tag, Herr Nachbar!
I think there is a great need for (cheaper) caliber specific movement holders, so if you are good at 3D printing, that may a be an interesting niche ? 🤔
Hello,
in the link above, there ist a universal movement holder implemented. I used it since a view weeks and it works fine.
Quote
There must be any sort of cooling. I use ethanol (we call it in germany "Spiritus" - it is ethanol with a additive so it is not possible to drink and because of this, there is no alcohol-tax on it). But IPA woud work, too. Water would be a solution, too, but I do not use this because auf corrossion of the tools. Eaven oil would be possible, but I'm not sure, that there would be no interference with the PLA.
Quote
Looks like a practical solution 🙂
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
