Rotary Evolution Battery Replacement
jreclocks
I have a Rotary Dual face watch ' TZ2  Evolution' with two separate movements, one with subsidiary seconds, the other with a date ring  has stopped working
I suspect the battery in this side has failed and needs a new one but how is the case  opened? Presumably the BackPlate and associated strap must initially be
separated from the case by removing the pin common to the three parts. The case also seems to be of three parts, two bezels and the main mid-section.
There are no "lips" on any edge and then there are the crowns!
Please see the photos attached. I would be grateful if any member who has experience or knowledge of this particular edition  of Rotary's 'reversibles' could
give me guidance
Thank you
John
You need to examine the sides with a loupe or eyepiece to find where to start inserting a blade tool, like an X-acto type knife. That is safer than a razor blade.
1 hour ago, watchweasol said:
His technique with metal tweezers is a bit suspect on a battery change hope they were NON conductive.
My bet is that they ARE conductive!  I use Delrin-tipped tweezers for this.
I am an amateur mind you...should you dial down on a hard surface and apply pressure to the hands while pressing in the battery?
Should your fingers be touching the dial?
Thank you  Clockboy, for steering me to the video of a model similar to the 'TZ2'. I was reluctant to 'jump' right in because
there seemed to be no way of extracting the stem without removing  a bezel.
The other worry was  lifting a bezel, the seams seem so close. I will let you know how I get on. John
The method used is the most likely way to access the batteries. You might be able to pull the stem out with this style of hand remover.To avoid scratches cover the stem first with clear plastic.
    • I used to just remove the stem pop the movement in its case then put the stem back in check everything then back on the timer.
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
