11 Anacd interchangeability
Does anyone know replacement parts for a 11anac movement. The Bulova part number is 574. It is a date driving wheel that I need. I have looked everywhere and am unable to find one. Is it the same in another movement maybe. Help would be appreciated   I have looked on eBay,cousins and a exhausted google search
thanks
50 minutes ago, Franktimex said:
I just went to the website it said it’s discontinued
According to the link below Your watch was made roughly between 1969 and 1976. Which is roughly 45 years ago which means basically all the parts have been discontinued as Bulova would no longer be manufacturing any of those parts. But that doesn't mean the parts aren't out there somewhere. The only thing disturbing from looking at the part up is that it doesn't appear to cross reference to anything else. But they probably made a lot of these so the parts are out there yes have to go and find them.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Bulova_11ANACD
14 minutes ago, Franktimex said:
I don’t want to have to spend 100 dollars for a 7 dollar part. But I guess this is the major pitfall of this trade and hobby
Perhaps you can find a donor movement and that would give you a lot of parts either for later use or for sale.
Oh yeah they are out there. They can be a gamble though. You know could be faulty or missing from a already scavenged movement.  However my main question is does anyone out there know what movements can you interchange with this date wheel surely there must be someone who knows.
I thought we answered this question?
Here's a popular place to look and it's free
http://cgi.julesborel.com/
The new find your watch you end up here
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=BUL_11ANACD
Then you click on your part number
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=Yc^DiiotUIfZgio
Which tells you you're screwed there is no cross reference
Discontinued and no cross reference. The problem is how popular was this part?
Then one of the moderators did this to somebody asking a question so I will torture you with the same answer have fun reading.  Then set up a search on eBay sooner or later almost everything shows up on eBay it might take a while. I remember were I will work as a watch that just needed a stem it took almost a year to get all the components for a variety of interesting reasons. The parts are out there just takes a while to find them or have them show up on eBay you feel lucky. If it's a part that broke a lot
https://www.watchrepairtalk.com/topic/14621-parts-availability/#comment-168106
2 minutes ago, Franktimex said:
Is 11 Anacb and 11anacd interchangeably they are in the same family does anyone this
Then following the procedure above it looks like the answer is no
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=Yc^DiiotUIfZgim
There is still a minor possibility that it does cross reference to something probably Bulova problem is we need a Bulova cross reference book I wonder if such a thing existed? This is the problem and watch repair is that not all the technical documentation filtered out of the factory. There just isn't a cross reference for every single watch your data Booker sheets a technical guide. It's the challenge of watch repair finding parts
37 minutes ago, Franktimex said:
There is a interchagibility book
The only minor problem with the cross reference book the reference material and everything else is it has a publishing date. There is always a tiny possibility something manufactured after the date might interchange. But there's also the likelihood that it interchange is with nothing.
It's one of the mysteries and watch repair other than engineers like to keep their job and apparently they keep their job if they keep designing innovative new things. So the mystery is why are there so many variations of watches. Although typically spare parts servicing and repair was not on the mind of the manufacturer at the time they were manufacturing which unfortunately contributes to the problem.
This ebay seller lists parts for an 11ANAC and also lists a #576 Date Indicator. However, the 11ANAC didn't have a Date Indicator so it is likely from the 11ANACB or 11ANACD. Perhaps message the seller and see if he can provide more info. EDIT: The seller has the dial from the movement listed as well, and I have the same watch. The movement in that watch is an 11ANACB.
Also, you might try here.
There are some Bulova interchange guides here.
Edited by GuyMontag
Revision: On part number 574 for the Anacd there is no day changing finger. But on The 11 anacb there is. However, because of that extra finger it was causing the date to change twice. Once at 12 and again at 10:30 am as there is no dial spacer on the ANACD this was causing the extra changing of the date.  So using a .5 mm flathead I broke off the small tab that changes the day. This seems to have fixed the problem. So can you use a 574 anacb on a 574 anacd yes you can if you break off the day changing tab.
thanks for all your help.
    • Ok, with the parts You have, the easiest thing to do is vibrate a new hairspring, of cousre for 16800 BPH. A couple of balance screws will be not enough, at least 3-4 aditional couples will be needed. And this if You have that many free holes. And cutting 75 teeth table for the contrate wheel is the other reasonable option Different things may have happened to the clock - the contrate wheel may have be replaced from another modification, the platform may not be original, the hairspring may have been replaced and vibrated for 18000 or the entire balance may have been replaced wit the wrong one...
    • I also agree with @mikepilk and @Waggy. Your readings look good. The amplitude drop between the horizontal postion and the vertical position is nice and low (only 18° difference).  The delta of 17 sec (-3 to +14) between those positions is absolutely ok. If you really wanted to improve on this, I think you'd have to look into the poising of the balance wheel (not the spring, which looks perfect). But that's a total overkill for this kind of movement. Leave it be.
    • I've just finished refurbishing a Memostar Alarm with AS 1931 movement (same as 1945 but with date and running at 21600). I was also surprised how many parts are available at Cousins. Like you, I was missing the alarm stem (Cousins stock them) and I needed new crowns. It's a nice simple movement for an alarm, easier to service than a Seiko Bell-Matic. BTW I made a note in my Servicing spreadsheet: "Pull out winding stem before removal".  It may have just been wear on my movement, but I found that the yoke could move out of the clutch if the stem was removed in the normal position (like some ETAs).  You might find this interesting
    • I picked up this alarm watch at a flea market several months ago and recently decided to investigate.  I am not finished, but well on my way. As you can see, there was significant water damage.  Running these parts through my L&R cleaner was not enough to clean them, so I did manual cleaning with one-dip and cotton swab (the dense pointed kind).  The wig-wag was stubborn--the two gears would not release from the plate.  I soaked it in Kroil overnight and that did the trick. There was some rust on the balance staff, but not actually on the pivots themselves.  Nevertheless, I chucked it a step-chuck on my lathe and burnished the pivots. The watch is running and I have confirmed that the alarm drive train is functioning.  Since I am missing a stem for the alarm, I have not done the final assemble of the alarm components.  Surprisingly, there are lots of parts available for this movement on Cousins.  I will probably get a couple of stems and maybe some other parts that I deem necessary. The watch is running at weak amplitude (about 190) and shows some poising issues.  I will work on that. The last two pictures are after partial reassembly.
    • Hello and welcome to the forum.    Enjoy
