I purchased my one from a clock repairer in Staffordshire then I had it fully refurbished by Graham Baxter (http://www.delphelectronics.co.uk). HOWEVER he no longer re-furbs them as there is not enough demand or profit. He still  produces watch timing software. I now use a cheap Indian cleaning machine (JANTA) which is a copy of a Elma which gives me excellent results.
PS is you enter L&R or Varimatic in the search box on this site there is lots to be found on this machine.
JANTA
I've actually got quite far, have managed to get hydraulics sorted and the synchronisation.
On to the ultrasonics.
Now the ultrasonics light did not come on, the fan kicks in so the switch is working that starts the ultrasonics.
The bulb light up for a few seconds and died.
I have found a replacement and am waiting for it. However the dial control looks to not being doing anything at all.
Does some one have a pic of the underneath with that bit in particular. I want to make sure nothing is missing as I do not see how it would do anything as it looks like a loose switch ( bit at the front)
Thanks in advance
Sent from my ONEPLUS A6003 using Tapatalk
Thanks clockboy , I do have this document , just need some detailed pictures to see if there is a part omissions in the front switch as I don't understand what it actually does!
I was told by the guy who re-furbed my L&R that the original wiring is suspect with NO earth. So he re-wired it, I do not understand electrics so I just took he word for it. What I do know is when it is up and running it is a great machine and cleaning a watch is almost a pleasure.
Quote
Is that big glass bottle a valve rectifier?
It is a single valve  oscillator. I would have suggest high voltage leakage testing and if necessary replacing any capacitors before you even attempt to power it up (but I'm too late I believe).
.. and of course be careful around the ultrasonic circuit, those are pretty high voltages.
The light bulb is quite probably an active part of the circuit.
Edited by AndyHull
4 minutes ago, jnash said:
Yep replaced valve, then capacitor s blew
The dodgy capacitors are the reason the original valve blew.
When fixing old valve gear, always start with a test and replace of capacitors.
Resistors rarely go badly out of spec, and when they do, they generally increase in value, but capacitors are far more likely to be leaky, or wildly out of spec. and that introduces DC in places where only AC should go.
1 hour ago, rodabod said:
1450V on the secondary..... F* that!
I wouldn't recommend that, nor indeed licking it. However since you don't actually need to touch it when it is switched on, you should remain completely unf*d.
Observe some simple precautions and you should be perfectly safe. Its a bit like crossing the road. You shouldn't do that with your eyes shut, and neither should you work on high voltage with the power on.
Keep your left hand in your pocket if you decide to prod things with anything remotely conductive, that way if you do get a tingle, it doesn't go through anything vital (like your heart).
The circuit is relatively safe in the sense that you can see all the bits that will bite you. Its not like working on large switch mode power supplies, X-ray equipment or colour CRTs, which can be pretty angry, even several hours after being switched off.
You might like this Youtube channel. He is old school like me, and works on tube equipment and CRTs. He is a little more blase about touching stuff that I would be paranoid about. He does work with an isolation transformer however, which I would recommend if you are planning on doing much work with anything over about 50V.
BTW Colour TVs work on up to 30kV plus. Even monochrome CRTs use several kV
X-ray tubes go even higher. The xenon flash tube in a small compact camera can blat you with a couple of kV if you are not careful. Don't ask me why I know.
Edited by AndyHull
I have been following this post with interest as I have a varimatic which at present is in garage waiting a fix. The guy who originally re-furbished the machine said the original wiring was poor and dangerous. When I purchased the machine it worked for a while then it caught alight and blew the house fuse.  If I remember correctly the original wiring circuit was was not earthed.
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ? Stearic acid experiment underway,  its started to melt at around  65° C. The idea is to find a large cap jewel to suspend over the vapour release.
    • That's the size of my grandfather's Ernest Borel watch. Definitely not a lady's watch! 👍
    • Thanks H It does have a big crown for the watch , it could be considered a ladies watch these days i guess, it measures 33mm case 36mm with that large crown 18mm lug space. A tad small for a guy of today, but still very wearable. The photo was deceptive so here it is adorning my 7 1/4 " wrist. It need some love to make it run better. The hair coils are touching so running a bit fast at the moment,  not caused by magnetism, and maybe just a clean and a service. The dtal is in fantastic shape.
    • That's one beautiful timepiece! Love the big crown in proportion to the case. Perhaps a ladies' watch, but I don't think so. I have a "modern Ingersoll" watch, but it has nothing to do with the original brand (Miyota 9015 movement). Interesting synonym for synthetic oils! 😆 There is, of course, a limit to how large a volume of oil epilame can bind and hold in place. If the oleophobic effect is too strong then it can become a problem. I'm not sure where I heard or read it, but as I understand it, the active ingredient in a bottle of epilame is extremely small and more than 99% of the contents of the bottle is just a transfer agent. If the active ingredient becomes too concentrated, which it can become over time, or if the product is of poor quality, the oleophobic effect is amplified. This in turn causes the applied oil to look like a gummed-up ball on the surface of the treated part. If that happens, we know that the active ingredient has become too concentrated. What we want is for the oil to bind but not to the point where it is formed into an excessively round ball on the surface. The highlighted text in the patent that you refer to describes well the problem that can arise with too high a concentration of the active ingredient. However, I would be extremely surprised if the entire amount of oil leaves the treated surface as water on wax would. At present, I am convinced that the analogy between wax and water on the one hand and epilame and oil on the other is incorrect. Epilame is described as binding and that is also my absolute experience. Epilame probably has some repelling effect but that is not its main purpose and that is not how epilame is designed and works. The method of abrading the epilame treatment from the section of the pallet stones coming in contact with the escape wheel teeth seems after even more research to be well established, but if it actually works, if so how and why is beyond what I can currently understand. Perhaps it is just to do and trust that it is based on well-established experience. I am, after all, inclined to think so.
