Prototypes
Hi All,
New member here so please be gentle. Being new I feel the need to contribute in some way, but don't have much expertise to offer. So I thought I would post some photos of watch prototypes I make in my free time. Please be aware these ae thrown together from what I have available. They are incomplete and effectively just thrown together to see if a concept works for me. Hence there will be missing hands, unfinished dials, scratches and dust! The brand name is one that my partner and I came up with one night and is just something to fill space on the dial!
Anyway, caring is sharing so here we go...
I should mention when I say production I mean by myself! For example the first watch will probably be made from etched/engraved sterling silver with enamel infill. I should hopefully have a pad printer setup by Christmas. Cases are bought pre made and adapted using basic hand tools. Pretty much just stuff that anyone on this forum can do at home.
1 hour ago, Klassiker said:
Thanks for sharing! I like all three, with the first a clear favourite. Not something this forum member can do at home!
Thats very kind of you to say, it has made my day. Apart from my long suffering partner I've never showed anyone my work before.
3 hours ago, spectre6000 said:
How are you making things? Dials, hands, etc. What are you doing to modify cases? Very interested.
Dials are made from small sheets (50mm x50mm) of sterling silver purchased from cousins. I use 0.3mm thickness so I can add paint etc without it becoming to thick. Dials are marked out and cut with a jewellers saw. I use sterling silver because it’s quite soft so I can dome it slightly if I want. I also create negative relief dials and silver is the right colour for a lot of my designs. After this I attach dial feet appropriate to the movement I’ll be using.
All dial designs are created in Inkscape. I then decide how I will recreate this for the watch. The first watch I posted (I jokingly call it ‘decotime’) is a negative relief dial, so I print it onto water slide decal paper, and apply this to the silver dial. The decal is then protected with numerous coats of acrylic lacquer, which is flatted and polished after it’s fully cured.
If I decide I really like a design and decide to turn it into a proper watch I will do the dial differently. Using the first watch as an example the silver dial will now be made from 0.5mm sterling silver. This will be acid etched leaving the numbers and the rings behind. The outer ring will be filled with black enamel, and the inner ring will be made from a grey polymer clay.
Cases and hands are harder to make big changes to. I generally start with a case that is the right dimensions and will fit the movement I want to use. If I find a case I really love that my movement will not fit I will change the movement I’m using. The first watch I posted I wanted a vintage look for but didn’t have a 36mm vintage case. So I took a modern case and sanded the bezel to have a flatter profile that worked better with the acrylic crystal I fitted. I then filed the lugs and softened the sharp edges of the case with sand paper. I then went crazy with the polisher!
Hands are simply a case of finding ones that are roughly what you are looking for, making slight shape changes with a file, painting and reluming.
18 hours ago, Angrybear said:
It was quite a shock coming from London!
Yeah, but London is a proper city. Munich is called the "Millionendorf", a village with a million inhabitants, which seems about the Goldilocks size. London, like Berlin, has much more vitality, but I'd rather live here. I still miss the UK (though less and less in the past few years). I spend my New Year's Eve cooking and watching the Hootenanny on the BBC!
Interesting... Millionendorf. Leave it to ze chermanz to come up with a word like that. Wittgenstein and all that; language and vocabulary opening new avenues of thought. I used to live in Dallas (pop ca. 9MM), and moved to Denver (pop ca. 1.5MM) a decade or so ago. The destination aspect may have something to do with it (people just want to be here rather than resigning to living here due to a job or something), but I haven't found anything in terms of amenities, commercial opportunities, etc. lacking. Meanwhile, in Dallas it took a good hour to get from pretty much any point A to any point B due to traffic, whereas here we live up in the mountains to the west without any distractions from the city (aside from tourists driving/biking through), but can be anywhere in only 45 minutes with a good 20-25 of that just being getting from the mountains down to the flats. I'm sure there are other manifestations of this, but I haven't finished my coffee yet.
18 hours ago, dadistic said:
That airplane is great!
How the heck did you make that?
I wish I could take credit for it. I’m a bit of a watch part hoarder and bought it thinking it would be fun for a future project. Well turns out this is the fun future project! If I remember correctly it came from a company in Switzerland.
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
