Prototypes
Hi All,
New member here so please be gentle. Being new I feel the need to contribute in some way, but don't have much expertise to offer. So I thought I would post some photos of watch prototypes I make in my free time. Please be aware these ae thrown together from what I have available. They are incomplete and effectively just thrown together to see if a concept works for me. Hence there will be missing hands, unfinished dials, scratches and dust! The brand name is one that my partner and I came up with one night and is just something to fill space on the dial!
Anyway, caring is sharing so here we go...
I should mention when I say production I mean by myself! For example the first watch will probably be made from etched/engraved sterling silver with enamel infill. I should hopefully have a pad printer setup by Christmas. Cases are bought pre made and adapted using basic hand tools. Pretty much just stuff that anyone on this forum can do at home.
1 hour ago, Klassiker said:
Thanks for sharing! I like all three, with the first a clear favourite. Not something this forum member can do at home!
Thats very kind of you to say, it has made my day. Apart from my long suffering partner I've never showed anyone my work before.
3 hours ago, spectre6000 said:
How are you making things? Dials, hands, etc. What are you doing to modify cases? Very interested.
Dials are made from small sheets (50mm x50mm) of sterling silver purchased from cousins. I use 0.3mm thickness so I can add paint etc without it becoming to thick. Dials are marked out and cut with a jewellers saw. I use sterling silver because it’s quite soft so I can dome it slightly if I want. I also create negative relief dials and silver is the right colour for a lot of my designs. After this I attach dial feet appropriate to the movement I’ll be using.
All dial designs are created in Inkscape. I then decide how I will recreate this for the watch. The first watch I posted (I jokingly call it ‘decotime’) is a negative relief dial, so I print it onto water slide decal paper, and apply this to the silver dial. The decal is then protected with numerous coats of acrylic lacquer, which is flatted and polished after it’s fully cured.
If I decide I really like a design and decide to turn it into a proper watch I will do the dial differently. Using the first watch as an example the silver dial will now be made from 0.5mm sterling silver. This will be acid etched leaving the numbers and the rings behind. The outer ring will be filled with black enamel, and the inner ring will be made from a grey polymer clay.
Cases and hands are harder to make big changes to. I generally start with a case that is the right dimensions and will fit the movement I want to use. If I find a case I really love that my movement will not fit I will change the movement I’m using. The first watch I posted I wanted a vintage look for but didn’t have a 36mm vintage case. So I took a modern case and sanded the bezel to have a flatter profile that worked better with the acrylic crystal I fitted. I then filed the lugs and softened the sharp edges of the case with sand paper. I then went crazy with the polisher!
Hands are simply a case of finding ones that are roughly what you are looking for, making slight shape changes with a file, painting and reluming.
18 hours ago, Angrybear said:
It was quite a shock coming from London!
Yeah, but London is a proper city. Munich is called the "Millionendorf", a village with a million inhabitants, which seems about the Goldilocks size. London, like Berlin, has much more vitality, but I'd rather live here. I still miss the UK (though less and less in the past few years). I spend my New Year's Eve cooking and watching the Hootenanny on the BBC!
Interesting... Millionendorf. Leave it to ze chermanz to come up with a word like that. Wittgenstein and all that; language and vocabulary opening new avenues of thought. I used to live in Dallas (pop ca. 9MM), and moved to Denver (pop ca. 1.5MM) a decade or so ago. The destination aspect may have something to do with it (people just want to be here rather than resigning to living here due to a job or something), but I haven't found anything in terms of amenities, commercial opportunities, etc. lacking. Meanwhile, in Dallas it took a good hour to get from pretty much any point A to any point B due to traffic, whereas here we live up in the mountains to the west without any distractions from the city (aside from tourists driving/biking through), but can be anywhere in only 45 minutes with a good 20-25 of that just being getting from the mountains down to the flats. I'm sure there are other manifestations of this, but I haven't finished my coffee yet.
18 hours ago, dadistic said:
That airplane is great!
How the heck did you make that?
I wish I could take credit for it. I’m a bit of a watch part hoarder and bought it thinking it would be fun for a future project. Well turns out this is the fun future project! If I remember correctly it came from a company in Switzerland.
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
