What the hell am I doing wrong
Paul80
  • 4 months later...
The Curse has struck again.
This time I had a 7009A that needed a new Balance, (Its spring was damaged). I bought a brand new Balance which arrived this morning and a quick inspection prior to fitting it revealed the impulse jewel is missing, this is a brand new sealed in its packet item.  Think someone is trying to tell me something 😞
I think I will give up with the 7009A movement now.
Never had a problem with Seiko parts. Is there any sign of shellac/glue ?
Where did you buy the part ?
For second hand Seiko parts, a useful source is https://speedtimerkollektion.com/ , they have complete balance+cock for about 6 euro.
1 hour ago, Paul80 said:
The ones speedtimerkollektion sells for 6 are actually broken, his good ones are about 17 and up. Which was why I tried a brand new one from Cousins also at 17.
Report it as a fault to Cousins. You may get a refund.
On 10/1/2021 at 11:11 PM, Paul80 said:
the 7009A, out of the 5 I got working The same thing has happened to 4 of them and that is after working fine for 4 to 6 weeks they suddenly just stop and when I check they have all stopped for the same reason and that is the impulse jewel has fallen out of the balance.
Today's one I did manage to find the jewel and under the microscope managed to get the jewel back in with drop of shellac to hold it in place
This is a fairly modern calibre from the 1970s. When I started out servicing/repairing I was under the impression that all impulse jewels (just like pallet jewels) were always fixated with shellac. That is until @nickelsilver mentioned that the impulse jewel on most (all?) modern calibres is friction fitted (if I recollect correctly?). What makes you think that the impulse jewel is fixated with shellac on the 7009A (except for the fact that they're falling out)?
Don't think my reflection will shed any new light on the problem, but I'm curious...
I have found a low cost solution to fixing my problem with these Balance's
I found a couple of sellers on Aliexpress with Balances for the 7009 and at only £2.50 it was worth a punt to see if they were any good or even if they fitted.
First batch arrived and I have fitted a couple of them and sofar everything is working well, so for now the problem is resolved, unless they also loose their impulse jewel in a few weeks like the old seiko ones did. still £2.50 is much better than £17.99 that Seiko ones cost.
Will update the post in a few months if they are still working or have also failed but looking good sofar.
Paul
Paul
I'd never thought of looking on Aliexpress for balances, they're amazingly cheap. How do they look for quality close up?
Do you have a timegrapher - be interesting to see how it performs in different positions.
Edited by mikepilk
These have been mentioned in previously, hard to find topic. The person reporting said some didn't even really work, like hit and miss.
    • On the link that I posted, ne of the watches has no crown and another has an a crown that is not square to the case. Does a broken crown signify that the movement may be quite corroded, hence the stem has broken,  and does the bent crown simply signify that the stem is bent? Unfortunately as the seller has a bid on the items, he is now reticent to prise the casebacks off in case he damages something. The seller did reply with this email though. Hi again Michael - brief descriptions; Oris x 2, dials and hands ok and they set ok and one I just wound and it has been running for a few of minutes as I write this response. Rocar, dial ok no crown. No name dial no good and can't pull crown out to set. Roma dial and hands ok, I think it is pin pallet movement. Unicorn, good dial and hands and plexiglass ok for age. All cases and plexiglasses show wear except as mentioned. I have no idea what movements are fitted or condition so please if you do consider bidding, please do so accordingly as I don't like to disappoint my customers - regards and thanks again for your interest - Jim
    • The incomplete Vertex DD is a new project to sort out.  The Seiko gen 1, is my favourite watch to wear and is my daily.
    • To be fair it was a beautiful 'bumper'.  But, there was some loose parts in the case.  Perhaps 'pig' was a bit excessive 😄.
    • Hello and welcome to the forum.   Enjoy
