Cleaning Problem
Hi,
I've hit another problem today unfortunately. I was cleaning a Sekonda when I noticed the following on the plate - bit hard to miss really as it was clean looking before it went in and is now filthy (but only on one side though). In case the photo is not too clear, it is covered with dirty brown stains. The only thing I can think may have happened is I contaminated the cleaning fluid. I did notice on extracting the mainspring there was some kind of residue on it (but not in the barrel though). I didn't think much of it and went ahead with the cleaning.
One side of the plate, the barrel and cover, bridges and some other parts are now filthy. I have tried vigorous scrubbing, soaking in one dip and running through the ultrasound again but it's had no effect. It almost looks as if it is part of the surface, rather than something on the surface. I have disposed of the cleaner and rinses, but am reluctant to try again as it may ruin more cleaner. Anybody any ideas of what I could try, or is it a goner? Thanks.
Hi chadders,
I've never encountered this problem but I would venture that the metal has been stained somehow (chemical reaction?) or is actually showing (or almost showing) the base metal of the plate. I can't tell without observing the actual plate in person. Have you tried to rub it with Rodico? Any difference? If at this point the surface is smooth and without any particulates that might endanger the working of the watch, I would simply try and live with the problem...other than that, I don't know what to tell.
Just a thought,
Cheers,
Bob
PS. Check for magnetism too, just in case.
Chadder what cleaning machine do you use. The reason I ask is I did have similar issue when I used to use an ultrasonic cleaner & I had the heat far to high.
Also I had cleaned some really dirty clock parts previous & I think the combination of the high heat & contaminated cleaner stained the watch plate.
I changed the cleaning solution & the problem never re-appeared.
I don't now how you do but i use a little bowl in the UL-bath . It's from stainless steel and it work great . I have tried plastic bowl but that took away the ultrasonic waves . And there isn't so much cleaning fluid i have to waste every time i clean .  I can't  see why you shouldn't be able to clean the plate and use it . As long as the jewels are clean . And i can give you a tips .Put it in baking soda . A cup of warm water and a teaspoon of baking soda .
Thanks everybody. I had actually run everything through the cleaning machine apart from the mainspring, which appeared to have some plastic type residue on it. I washed this seperately and then decided to run everything through the US - big mistake! Same as rogart63 I use small glass jars with fluid in the US. I think clockboy has a point as well, I have noticed in the past that the US can get too hot using the heat as it is not controllable. This can lead to tarnishing, which may have made things worse. I seem to automatically turn the heat on though.
The affected parts are definitely stained, nothing on the surface so I suppose they are useable, just ugly! I'll give rogart63s suggestion of a bicarb soak a go and see what happens. Thanks.
Is the surface actually stained, or has some of the plating been eroded in the cleaning process?
I was going to say the same thing Geo. These are nickel plated I believe and I thought the yellow was the brass showing through.
I have seen this happen in the past especially with plated barrels where the plating actually peels off when rubbing with Rodico.
I had the same thing happen to a much larger extent! I had an extremely dirty watch that I left to soak while I went for a pint or several I then forgot about it and four days later had gleaming gold coloured plates! All of the nickel had dissolved away! I use Elma 1;20 btw
The photo doesn't show it very well unfortunately but the residue is brown. I'm pretty sure it is a residue as after trying a bicarbonate soak without success I scraped it with a razor blade and it came off. Or at least some of it did. I'm trying to think now what type of solvent I could try on it - something strong preferably!
Me too, Mark! At first, I thought it was showing the base metal (as in my original post) but gave it a shot as chemical reaction (and there you have it, elma at work)...I'm glad the elma problem came up!
I've been using L&R for a while and everything comes out all right from my cheap ultrasonic.
By the way, do the Zenith cleaners have any of those side effects? I'm about to experiment with their stuff so any thoughts/info will be appreciated since they are not cheap. Thanks in advance!
Cheers,
Bob
This is using L&R products. However, as I said in my op (and I now see may not have been clear) I think I contaminated the fluid. When I took the mainspring out of the barrel it had a plastic feel to it and some substance peeled off it. I then put everything apart from the ms in the cleaning machine, and it all came out fine. I cleaned the ms seperately with one dip. I then put everything, including the ms, through the ultrasound. This is where whatever happened, happened.
I believe the new springs (it still might have been new on a vintage watch due to previous repair) come with a coating and it is not necessary to oil their surfaces...maybe that coating was coming off and screw up your solutions! In any case, I believe that from now on, my main springs will go either separate or hand cleaned, just in case!
    • I wish to share my experience with thyme tea with everyone. Six months ago when I had my second bout of Covid, my chest was so congested that breathing deeply hurt. Coughing was pure agony. And with a 40°C fever that comes back every 6 hours when the level of paracetamol in the blood falls, I was willing to try anything.  Then I saw this video on YouTube and I decided to give it try. I drank a cup of the stuff and went back to bed. When I woke up about an hour later, I coughed up a golf ball sized lump of greenish-yellow phlegm. And almost immediately, all symptoms suddenly abated. 24hrs later, I was feeling perfectly fine. I repeated an ART test and it was negative. I started recommending it to some of my friends and many of them found it useful, although some claimed it had no effect. I had another round of Covid last week. I tested positive on Thursday and although the symptoms were very mild, I drank a cup of thyme tea just to play safe. And by Friday evening all symptoms were gone. I repeated an ART test and it was negative. If any of you read this, try it out the next time you get Covid or the flu. Let me know your experience with thyme tea. @watchweasol, you might like to take note of this.
    • The problem is where the arrow shows.
    • Why is it when that little voice says, "This is a bad idea," we always want to talk ourselves out of it? I had the low blood sugar jitters earlier, but insisted to myself that I'd be able to oil an especially tiny cap jewel on my friend's Omega 1001. With lots of concentration, I nailed it. But when I put the hole jewel on top, it was too much oil and it squoze out everywhere. It didn't spread on the cap jewel much thanks to the epliame I'd applied, so it was more than it looked like from the top. Back in the cleaner, dried, re-epilamed, dried. Time for a second try, but now I was more shaky even than the first time. "This is a bad idea," my brain told me. "Take a hike, brain," I said as I watched the oiler jiggle into my microscope's frame. And just like that, the jewel was a tiddlywink and flew out of sight in the blink of an eye. With a strong UV flashlight and the waste of a lot of time I did find it on my desk, but that's some stress I didn't need in my day. So friends, listen to your body, and listen to your brain when it tells you now's not the time for precision work.
    • I dont think Hector means there is an issue with the hairspring at the collet, only that the collet is not centered over the jewel hole. You can check this by unmounting the hairspring from the balance and recentering the collet with the balance jewel. If the coils remain undisturbed then i believe it unnecessary to dismount the collet and only adjustment at the stud is needed to bring the hairspring to shape. If any of coils have been accidentally bent then reshaping of hairspring separately would be required.
    • @HectorLooi Thanks.  I do have a microscope. But no camera to show what I see in it.  You are correct that some coils overlap. In particular the outside one where thr regulator pins go  overlaps the previous one. I will try your suggestion.  I am surprised that there is an issue with the collet as I don’t see how I would have messed that up.  I didn’t think the impulse jewel is damaged as I can check it in the microscope. I meant that when I put the balance I am always wondering if I managed to set it correctly in relation to the fork.  Thank you all. So I think I will take @HectorLooi advice and note that the hairspring needs fixing and go practice with my second ST36. In any case this one also has the setting lever screw broken in the setting lever.  I think I’ll also order a dial, case, hands and strap to make a watch out of that second movement.  I see a bunch of them on AliExpress or eBay.  Anybody has recommendations?
