Patek Cal. 10-200 Stud Holder vs. me
mzinski
So I’ve been cleaning and bringing back to life a Patek cal. 10-200 (you can see my very recent question looking to confirm the caliber since it’s unmarked).
So far, everything has come together quite nicely until I oiled the balance wheel jewels.
As you can see it’s the type in which the balance is removed from the c0ck to access the upper jewel.
Upon reinstalling the balance I noticed the stud and stud holder is unlike anything I’ve encountered before. The stud slides into the stud holder and is clamped by the upper two screws. When not clamped, the stud can freely slide inwards, outwards, and rotate. At first I thought this was a clever way to allow watchmakers to adjust beat error without bending the spring or twisting the collet. But much to my frustration, I’ve found it to be an endless area of tweaks to try to locate the right spot and angle for the stud.
Like I said, it looks like a clever design but maybe too clever for me. Can anyone recommend best working practices to incrementally adjust the stud into the right spot?
The stud should end up where the hairspring naturally rests. You should not twist the stud to adjust the hairspring.
Should I release the power in the mainspring, bring the pallet fork to neutral, bring the regulating adjustment to 0, then reattached the stud?
Should I insert the hairspring into the regulator pins before or after I attach the stud?
Power off, stud cap screws loose, insert stud. HS in pins, wiggle watch a little so everything settles. Screw down stud cap screws.
From there, if you need to adjust anything adjust- beat error, move the hs collet. HS not centered in regulator pins, adjust. HS not flat, centered overall, adjust.
Ideally with everything "relaxed" and snugging up the stud cap it should all be good. But a watch this age has seen many watchmakers and probably needs some loving.
Thanks! I followed that procedure - and - voila! Manageable beat rate and 0.1 beat error. However, the delta between hanging positions and flat positions is significant (max delta of 60-sec). I suspect the pins are a bit tight based on that result and observing the HS doesn't float between them.
Before you go adjusting the pins, I think the delta is in part caused by your hairspring being out of flat. You can see it in your last shot - the hairspring appears cupped, meaning the overcoil is naturally sitting too low and is being pulled up when you fasten the stud. You should be able to see this better with the balance out of the watch, and maybe the hairspring off the balance. Make sure I am not wrong before you go messing with it though.
But yes the pins may also be too tight. There are likely several small distinct problems. It is common on old pocket watches for the pins to be pushed together. I think at one point it was considered acceptable practice.
Edited by JohnC
    • You could also use a very fine artist's brush to brush between the coils.  If you get a size 00 or even 000 that should be small enough for convenience, and with bristles so fine that they are incapable of damaging the hairspring.  Get a good one though, like Windsor-Newton or similar.  I have never had a Windsor-Newton brush shed on my art or other work.  You want a soft brush that will not shed.
    • Sounds interesting but how do you push the button if you’re holding both ends? the large current draw overheats after 3-5 seconds and the thermister triggers. A great tool for magnetizing things but I’ve not be able to ever demag anything with it because the emf is so strong it pulls the item off center (down or up).   I paid $89 bucks for it from  CAS-KER, if someone on the board wants it I’d gladly sell it for $25 plus shipping (probably US only otherwise postal costs are prohibitive). Just sent me a note offline.
    • Hi. First thing to do is measure your oil movement as the vx32E and the 43 look very similar but one is a couple of mill smaller the vx32E.  Also the canon pinion heights differ attached tech sheets for 7N22. And  VX43, check details on the sheets. 7N22A_29A_33A_42A_43A.pdf VX43.pdf Hattori VX32E - Specification.pdf Hattori VX32E - Disassemble.pdf
    • I was spitting out flowers and leaves for 10 minutes,  fortunately 3  people saw it and promptly whipped out their phones to film the quick " nothing to see here " recovery  🤣🤣
