Quartz movement with a stuck seconds hand
lorax
The movement pulses normally and the battery is the correct voltage. It's a shiojiri movement, not sure what model. The behavior is it will run normally for a few seconds, the seconds hand will get stuck and move slightly backwards and forward for a few seconds then move normally again or get stuck doing that dance. I made sure the hands are seated correctly and tried using the tool that uses magnetic impulsion to run the wheel train and hands extremely fast (forget the name, mine is unbranded) but neither fixed the issue. What else can I try besides replacing the movement?
Edited by lorax
4 hours ago, HectorLooi said:
Some background history and photos would be helpful. Did you drop it, went swimming with it, accidentally microwaved it?
Not all movement are designed to be serviced. Some are best replaced. So some good photos of your movement would help a lot.
Here's a picture of it. Unknown history, was like this when I bought it. The watch was made in the 80s so it's pretty old. The movement doesn't appear serviceable but I'm no expert. Also the coil isn't damaged, it's just light reflecting off it. Visually everything looks fine.
Edited by lorax
I'm afraid that is a throwaway movement. I'm not sure what would be a suitable replacement. I've never heard of shiojiri before today. It's a subsidiary of Seiko Epsom, so maybe there would be something suitable from their range of movements.
Good luck.
As mentioned, Shiojiri is a little used branding by Seiko, from the town where the factory is. The current compatible module should be the VJ12.
Thank you! I was worried I wouldn't be able to find a replacement, the one in it is the Shiojiri V515A which seems exceedingly hard to come by.
I am fairly sure a Hattori Y121 is a straight direct replacement for the V515A.
Chances are a very small drop of suitably light oil on each of the visible pivot points and then a reintroduction to your line release tool will probably get it running. Strictly speaking not a proper repair but when you have nothing to lose........!
That worked! Thank you!!! I'm still going to buy a replacement movement to have on standby though.
1 hour ago, KOwatch said:
treat yourself to a new $6 movement
The OP said that he will anyway as a backup. But beside that likely it will never be needed, I think that he did very well already, getting equipped with a pulse box, doing the replacement research, and applying with success the good hint he got. As in doing for the pleasure of  learning what is what is and why, not necessarily to get old watches working.
    • Ok so there is barely any response happening . After this last attempt i think I'm just going to give up on it because very few seem genuinely interested or even bothered or worried what may happen in the future. ( if someone can set me straight I'd love to hear it ) I would think anyone into watches has heard of Roland Ranfft, how they grew to love and depend upon his site for detailed information. And not just that, he also had a view about Ebay and everyone that visited Roland's site knew exactly what he thought about Ebay, Roland's site also had a secondhand watch sale side to it.  If anyone here could have done anything to preserve his site and keep it exactly the way it was.........Would you have done something to make that happen ?  Its been pointed out to me but not in so many words  that I'm probably coming across as an insensitive p.rick, truly I'm sorry about that, i say it as it is but no malice is intended and yes clearly I'm putting my forum membership on the line here. I'll happily shut up about it now, I've done all i can.
    • Thank you so much for posting this!  Although this movement is serviceable, there are no service notes that I've been able to find.  This is a great alternative!
    • Greetings from another electronics designer & programmer!   I suggest you get a batch of similar scrap movements from ebay - I found batches of Seikos very cheaply, I got seven of one type for £11 (or 11 Euros possibly?). Those were ladies, 4206B I believe. There are also mens movements at a slightly higher price; eg. https://www.ebay.co.uk/itm/134723051997 https://www.ebay.co.uk/itm/235565276549 They are cheap enough so it does not matter what gets messed up or lost & you can probably still get one or two working movements from a batch, even if some part are damaged when you get them. (I've had quite a bit from the guy in Holland, he usually has a good range of movements).
    • Please OH, we should all be proud of our collections what ever they are. If we can't show them off here then we can't show them anywhere. Our favourite gives us a story to tell of why we love it, that story also tells others something about ourselves. These are some of the things that make our forum and our community so amazing .
    • I can take pictures when I am home of what it looks like.  They will be phone picture as I don't have a camera in my microscope yet but I should be able to take a few views to give a good idea of the damage.
