Opening Omega DSOTM ceramic case
Recently I acquired an Omega Speedmaster blue side of the moon watch.  I would like to adjust the timing a little, and eventually do a COA but have some trepidation about the Zirconium oxide case. Since they are brittle I know that care will be needed to open it.  There are no slots for opening tools, just a slight recess in the back cover at the 9:00 position. Probably it is pressure fit with an o-ring.  That’s what it appears from the only cross-section picture I can find.  Thinking that maybe a Delrin tool tip or something similar would be needed.  Does anyone have any prior knowledge or experience with these cases?
Here is a picture of a watch which was dropped and broke.  Not mine, thankfully.  First, it’s obvious that the case has brittle properties.  But it appears there is an o-ring holding the case back on.
Do you have a decent set of opening and closing tools? Have you regulated a watch before? Do you have a timegrapher?
If the answer to one or more of the a bo e questions is negative, I think it would not be a good idea to learn on such an expensive watch. Build a modicum of experience first and get the right tools.
Please excuse the nitpick. The "back cover "is normally called case back, which when "pressure fit" is called "snap back". Although some types don't really snap as they are tick with a flush, hard gasket. Which could be the case with your watch.
I don't think a soft tool can open a tight case back, but some lever type tools are discussed in the topic below. The idea is to direct force in a precise and controlled manner to avoid scratches and worse.
@JohnR725 @jdm Yes it is the same, just the Sedna Gold version.  I have worked on thousands of watches and have all of the necessary equipment for repairs, jut not experience with this ceramic case back.
Also, regarding the picture of the broken case I found on the web, I don’t know if that watch is gen or rep.  I’m suspicious because there seems to be a large gap between the dial and date wheel and also there is a green gasket which doesn’t seem right for Omega.
Edited by OmegaMan
Additional details.
You'll need an Omega Co-Axial Micro-Star Regulating Key for Balance to adjust the timing...even if its only "a bit."  I thought that I could it with just a good pair of brass tweezers because I had lots of experience and good hands. One slip is all it took to kink the hairspring.
Edited by noirrac1j
@noirrac1jYes, I have one.  Thank you.
Edited by OmegaMan
one of the reasons I wanted the picture the back and it's good that you're saying it's identical except the color is I needed the reference number. I will inquire with somebody I know who works for Swatch group and see what the answer is..
then I'm curious about the timing it's already rated as a chronometer certified whatever what's wrong with the timekeeping?
Nothing.  It is within tolerance. However I would like to make a small adjustment and in the future it will need maintenance.
got a reply back my friend pasted the answer below. then not coming from my friend just as a reminder in addition to everything you do could cause something to break you still have to push the back back on once it comes off and there's probably a special ring order rings for the case press
Found it in the tech sheet. It’s a snap on case back. Use a traditional knife to open but pry at 9 o’clock only. Any pressure application to the lugs could snap them off
Also lever against the caseback only and not the case cause that could also break
Also as an aside, here are closeups of the moon disk images from the Omega Blue Side of the Moon Sedna Gold:
It’s supposed to be the near and far sides, but I think it’s hard to tell which is which.
Edited by OmegaMan
Added detail
    • The UK lots can be a 404 hit or miss, 6 - 10 watches can come in anywhere from 20 - 50 quid. I once had a 404 division of 8 watches for a fraction over 30 quid, one of them was a Smiths Astral model National 17 an absolute certainty for winner contender. The crystal was scrached up to the point of being very difficult to see the brand, something triggered a gut feeling in me and it paid off.
    • I just picked up this Mondaine quartz watch on tradera.com for £11. It's a non-runner so I will replace the Ronda movement (£10.95 at Cousins), polish the case, replace the case-back gasket, and replace the mineral crystal. Now, the problem is finding a suitable crystal. The original crystal is slightly domed (2.4mm thick dome), measures 36.4mm in diameter, and is 1.3mm thick at the edge. The closest I can get on CousinsUK is 36.5mm in diameter, 3.1mm thick dome, and 1.5mm thick at the edge. I think the replacement crystal would look OK, but the problem is finding a suitable glass gasket. The case diameter for the glass gasket is 36.9mm and the closest glass gasket I can find on CousinsUK is either 36.8x36.0mm or 37.0x36.2mm. I guess one of those glass gaskets could work but as you can see there's no way the 36.5mm domed crystal would fit the inner diameters of those glass gaskets. I guess I will have to give up on a domed crystal, no? So, the backup plan is to use a (1.5mm) thick flat mineral crystal as the diameters come in increments of 0.1mm. But, what glass gasket would be the better option? The one with an outer diameter of 36.8 (0.1mm too small) or the one with an outer diameter of 37.0mm (0.1mm too large). Again the case diameter for the glass gasket is 36.9mm. I believe I read or heard that the crystal diameter should be 0.1mm wider than the inner diameter of the glass gasket. Is that correct? I'm sorry for all the numbers. I've tried to make it as clear as I could. So, I'd appreciate your thoughts on this. BTW, measuring and sourcing crystals and gaskets is extremely time-consuming! 😓
    • Lots to choose from... Just sayin'.
    • New one on me too.  Is that corrosion on the crown wheel?  Let us know how you get on.
