Omega Seamaster Chrono Pusher
A friend has given me his Omega Seamaster Chrono case no 176.007 cal 1040 to have a look at .
One of the crono buttons has broken off and will need replacing as the button is missing.
I have looked at Marks video on replacing the pusher in the Omega chronostop thread which looks the same although Mark did a Breitling.
My question is I see Cousins do a Horotec tool for chrono pushers and pendant tubes , does anyone know if there is a cheaper alternative and also whether they would do the job on the Seamaster and if they would do Rolex pendant tubes (looking at doing my Oyster date maybe)?
Bit reluctant to shell out £144 plus vat etc if its no good.
Mark mentions in the vid about using pliers but as it's not my watch I'd rather use the right tool , if it was mine i'd probably have a go.
Thanks Andy
I don't personally like the Horotec set as the ends are quite brittle and can break easily.
These are the ones I use:
https://www.cousinsuk.com/product/chronograph-pusher-tube-fitting-removing
Still quite pricey, but I reckon they are better quality.
I can't be certain but it may be the blue one you need, but please double check the size you need before you order one in case I am wrong.
Brilliant thanks for that Mark , most appreciated
Update on this i've managed to purchase it off the owner , when he found out the price of the parts , so have ordered the bits for myself and the tool Mark recommended ,It's been running and working a treat on the watch winder results are good on the timegrapher so hopefully with a new pusher crystal and caseback seal i will have got myself a keeper :-)
The case has been knocked about a bit but it does date to 1972
Hey Andyclient, I have a Omega Chronostop Genéve with the same missing pusher button. What parts did you order for that - specifically, what pusher button? Thanks!
I got it from Cousins mine was ref:086st0005 which is the complete pusher assembly you will need to put in your case number to be sure though as they might not be the same.
Right before i posted i thought i would check as i have a chrono stop and they are different but Cousins still stock them.
My chronostop case is ref no145.009 which has a smaller pusher than the seamaster , Cousins part no 086ST0002 £42.75 plus vat plus p&p
Andyclient Please for help me, live in Poland, I bought the Omega as a project to revive .Ineed in the two pushers and the crown, you can help in getting parts, numbers ref. or what will fit replacements. For any help I would appreciate and behold my project...
First you need to find out which reference the watch has ? That stands on the inside of the caseback . It looks to be the same as the OP ?
Hi , if the case no is the same as mine a 176.007 then the pushers are 086st0005 and the crown is 43238st but i would check the case no first
cheers Andy
  • 3 months later...
  • 7 years later...
    • I'll have a look for it, but don't hold your breathe. Failing that I'll make another video when another bezel needs to be removed.
    • The UK lots can be a 404 hit or miss, 6 - 10 watches can come in anywhere from 20 - 50 quid. I once had a 404 division of 8 watches for a fraction over 30 quid, one of them was a Smiths Astral model National 17 an absolute certainty for winner contender. The crystal was scrached up to the point of being very difficult to see the brand, something triggered a gut feeling in me and it paid off.
    • I just picked up this Mondaine quartz watch on tradera.com for £11. It's a non-runner so I will replace the Ronda movement (£10.95 at Cousins), polish the case, replace the case-back gasket, and replace the mineral crystal. Now, the problem is finding a suitable crystal. The original crystal is slightly domed (2.4mm thick dome), measures 36.4mm in diameter, and is 1.3mm thick at the edge. The closest I can get on CousinsUK is 36.5mm in diameter, 3.1mm thick dome, and 1.5mm thick at the edge. I think the replacement crystal would look OK, but the problem is finding a suitable glass gasket. The case diameter for the glass gasket is 36.9mm and the closest glass gasket I can find on CousinsUK is either 36.8x36.0mm or 37.0x36.2mm. I guess one of those glass gaskets could work but as you can see there's no way the 36.5mm domed crystal would fit the inner diameters of those glass gaskets. I guess I will have to give up on a domed crystal, no? So, the backup plan is to use a (1.5mm) thick flat mineral crystal as the diameters come in increments of 0.1mm. But, what glass gasket would be the better option? The one with an outer diameter of 36.8 (0.1mm too small) or the one with an outer diameter of 37.0mm (0.1mm too large). Again the case diameter for the glass gasket is 36.9mm. I believe I read or heard that the crystal diameter should be 0.1mm wider than the inner diameter of the glass gasket. Is that correct? I'm sorry for all the numbers. I've tried to make it as clear as I could. So, I'd appreciate your thoughts on this. BTW, measuring and sourcing crystals and gaskets is extremely time-consuming! 😓
    • Lots to choose from... Just sayin'.
