Bergeon 6016--a very useful tool
LittleWatchShop
This tool has been in the watch bench and until today, I had never used it.
Now I know that it is invaluable.
Today I was fighting with a second hand.  Bending and bending until it cleared the minute hand and did not hit the crystal.  Had to remove the second hand many times.  This tool was made for the task!!
I use a longish sewing needle with the eye end cut off to leave a fork shape.  Bit of polish/cleanup to remove burrs etc (so don't damage had finish).  Pop it in a pin vice and there you go.  Bit cheaper than Bergeon !!  I use similar needles for hairspring manipulation.
The idea of this tool is the blades have a flat side and round side, slide it under whatever you want to remove,  twist the handle and the blades twist too, rising higher and detaching the part. Two downsides; one the flat side leaves a mark unless protected, the other is the "lift" is not that far. So at some point you might want to pry a little, and on driving wheels (which these were initially marketed for) you end up often with a bent or broken pivot. I don't personally know any pros who use this tool, but do know some that just call it the "pivot breaker".
Maybe I misunderstood its purpose. I thought it was for easing the second hand by bending it slightly.  i would not use it for prying off anything as it could bust a pivot as is said. Only ever used this idea once on a particularly 'stubborn' new centre second hand and it did the job without continual removal to reshape.
I've only tried this once, but it worked.  My Waltham 0s pendant watch has one of the tiniest sub-second hands I'd ever seen.  And when I had to strip it for cleaning, that tiny hand had to come off.  All I could come up with was a doubled loop of my slenderest silk thread (I do quite a bit of sewing too) with the ends threaded through a small bead.  One loop went over the long pointer-end, the other went over the butt-end, and I slid the loops up to the boss, slid the bead down the thread to hold the loops there, and gave a gentle tug on the free ends.  The hand came off neatly and without damage.
Later on, it was a little beast to put back in place, being difficult to manipulate carefully, but coming off was a breeze.
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
