Seiko Divers watch
I have this Seiko Dive watch that belonged to my brother who has passed.
The number I see on the back is 920060. I am trying to find someone who can repair it or install a movement if that's possible. I do know it is a perpetual movement and that's it.
Any help would be greatly appreciated. This watch has a lot of sentimental value and I would love to be able to wear it.
The watch has an 8f35 movement.  8F35-0019 is the exact model number and will the most results in an internet search.  The marketing number is SLR001.  8F35-0019 is the number you use when looking for parts.
I don't have a perpetual calendar watch but I do know that it is tricky to reset after a battery change.  The battery is supposed to last 10 years.
Hi  I have attached the service sheets for this watch. There is a section on battery changing, Its got to be completed within 3 mins as it erases the calendar data.  so before removing the battery obtain another to effect quick change. Also do not short the battery on fitting as this will have the same effect.   Read the sheets before attempting the change.
1962_seiko4F32A,8F32A,8F33A,8F35A (1).pdf
Always worth to remind quartz watch owners that their stopped piece will likely work again with just a battery changes, but that is not guaranteed either.
To reset the calender the below video by our host Mark Lovick as an alternative to official guides
4 hours ago, Michael1962 said:
I presume by perpetual that the watch knows when a leap year occurs? I would love to know how they do that?
As explained in the document and video above you set the number of years elapsed since the latest leap year.
If the battery is replaced when the watch shows its time to do that, it is not a necessary to go through the reset procedure.
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
