I’m no expert But........
transporter
You see this all the time on eBay like quoting from your eBay listing "has been tested and she is in perfect working order and she measures" Doesn't really explain what's been done. In other words the clock was wound up run a few hours it seemed to run its perfect.
I seen watches that were supposedly service they even put them on the timing machine And give you a picture usually the picture looks really bad at least to me. But that's your proof that the watches been serviced and is in perfect order.
On the other hand none of the Sellers are guaranteeing that the run for the next 10 years perfectly either.
Echoing what @JohnR725 said, and adding this: forget about running and serviced, guarantee me "complete and undamaged".  If all parts are present and in good condition,  I'll get it running.
I've seen watches with a damaged staff that could run in the dial-down position.  Some can be wound and will run, but damage to the keyless works won't let you set them.  I like complete and undamaged.  But that's not usually how they advertise them.
8 hours ago, nickelsilver said:
What makes you think it wasn't serviced?
I’ve had a couple of these movements as they are simple non complicated movements and perfect for training on. So to my non expert eye, the general condition of the movement, it hasn’t been cleaned so hasn’t been serviced. Look at the third wheel oil sink, you can see old discoloured oil and it needs bushing. I expect the intermediate wheel would most likely need bushing aswell due to the increased torque it is subjected to.
Can you see anything else? Always a school day for me mate
The seller doesn't state its been cleaned only that its working and been checked, regardless of servicing the clock is way over priced at £75.00 , its no doubt come straight from auction house to ebay in a matter of days.
This is one this seller sold earlier and states has been cleaned and serviced which it clearly hasn't:
https://www.ebay.co.uk/itm/Antique-Oak-1930-s-Napoleon-Hat-MANTLE-CLOCK-Serviced-And-Clean-/224387194322?hash=item343e84ddd2%3Ag%3AneMAAOSwZylgT4n8&nma=true&si=QZifpjPyF4kvM%2BLAIpv2f0O9FwQ%3D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
Ha, ok you are seeing more detail than I can! I was wondering if it was because it wasn't bright and shiny, after a long bath in strong ammoniated cleaner. That's the hallmark of having been serviced for some.
You are correct, but only because the seller has now changed the description. I did message saying that hoped they hadn’t paid for the services given to them as it clearly hasn’t been serviced etc. I wasn’t nasty just gave them a heads up and they said they would have words with the person who done the work ( obviously no one ) but they have now changed the listing description to suit what is actually being sold.
And it’s still way over priced!!!
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
