SantaCruzClocks
Good day, everyone!
My name is Kevin, and I have been a clock guy for about 30 years, even serving as the club president for a couple of years for the NAWCC chapter of Monterey Bay.
Pocket and wristwatches came through my shop on a cherry picked basis, and I've picked up quite a few over the years and left them languishing in my vault.
Now! I finally get the time to start playing with my own stuff, so I am overhauling a few choices to hand down to my family.
I'll pop in here off and on as I go - so here is a pic of what's currently on the bench.
Kevin
Welcome to the forum Kevin.
PS. I am not sure if I am looking at a watch or a pocket watch to tell the truth. Still a newbie. I'll take a guess. Watch? Don't ask me to identify calibre. I still get puzzled by the guys on here rattling off calibre numbers or 'this is based on this calibre'.
    • I see Mark has sorted this one out.
    • We need to identify the movement to help you, but the oldest of these Rolco watches use Aegler-Rebberg movements that lack a calibre number and are very difficult to identify. You may end up having to make or modify a stem to fit . Post pictures of both sides of the movement when you have it and the size of the movement and hopefully it’s one that has a calibre number.  Gruen used a lot of the same Aegler movements at the time and it’s worth comparing your movement with those if you can’t find it labeled as an Aegler or Rolex/Rolco calibre. Best Regards, Mark
    • Onlly a pro's eye would notice that OH, you've still got it old fella 🙂
    • The triple lobed spring, as you suggest needs to be rotated to remove it or replace it. Suitably shaped pegwood should suffice, but tools (shaped as you describe) for the purpose also exist.  If you have an assorted of replacement springs, a trilobe style KIF spring of the right size might fit.  The other spring securing the jewel also needs rotating. There is a slight opening in the setting at about the 5 o’clock position in your photo and one side of the spring should be able to be removed  there when rotated into position.  Hope that helps, Mark
    • As an update, it transpired the setting on the balance side, with the jewel had one flat end and one curved. When I rotated it enough it popped out. The chaton was entirely conical and a tricky customer but once lubricated and dropped back in I put the flat edge in first and poked it in with the peg wood tool mentioned above (I made it with flattening off the end then sizing with a pencil sharpener before poking a hole in the end) then rotated and it went in well.    For the other side, magnet searching for the spring has been fruitless.    thanks for the link to the other thread
