Heuer Quartz running fast
11 minutes ago, LittleWatchShop said:
Can someone provide an illustration or photo of the actual stepper of either this or similar vintage watch?
When the rotor sees a magnetic impulse, it will turn.  What stops it?  Well, if the magnetic energy is applied long enough for the rotor to settle to resting state, then magnetic energy itself stops it.  However, if the rotor only receives a magnetic impulse, then there must be a mechanical feature (like the keeper on a calendar ring) impeding the rotor from running past the point where it should stop.  THIS WOULD speed up the watch if it is not impeding properly.
Ideas?
Does this help, Seiko cal. 38 series from early 1970's...
Yes, this is great.  What about the "Second jumper?"  That is the term I should have used regarding the calendar ring (sorry).  If the Second jumper is not engaging, the sweep second wheel will just "freewheel" when it gets an impulse.
I have attached the best photo's I have of the rotor and the watch movement with the train bridge removed. This shows the rotor's position and the other wheels in the train.
I have contacted Star Times about a replacement circuit board and coil assembly, but they will not take an order from a hobbyist unless they are a NAWCC member. Cousins do not have the part. So I am probably stuck unless one appears on an auction site.
2 minutes ago, LittleWatchShop said:
It must be the jumper.
No. There are quartz modules without a seconds hand, or spring of any sort. There is nothing mechanical stopping the rotor, it stops by itself in a constant position because it's a magnet, with a North South orientation. That's why it is difficult to refit, it wants to stick to the stator, even when not energized. Most but not all rotor magnets are round (a ferrule), the one below is perhaps more revealing of its magnetic properties - polarization. Credit HSMAG
There are ways, I can order on ST without being qualified to even wash floors at NAWCC. If in dire need contact by PM.
Thanks for that info.  OK, then what if the rotor (or stator for that matter) have lost some magnetism over the years?  Or what if (by some rare event) the watch was put in a magnetic field that partially demagnetized the rotor?  The earth's magnetic field has been shifting!!  (this is true, but I am kidding about the earth causing this).
I suppose you would like to restrict this discussion to older stepping motor watches? Just wait until you get to new technology like making a stepping motor watch step backwards. Or clever ways to do away with the Trimmer capacitor and still get the watch to keep time.
I'm attaching a series of images that should be helpful.
In the image of the drawing of the watch casually your not going to see what you need to see. You have to look at the actual drawing of explaining how the stepping motor watch works to grasp what you're looking at in the other drawing. Specifically the  stater is manufactured to a very specific shape. So while it looks like the rotor is in the center and the hole itself is perfectly symmetrical it is not. But that will make sense when you look at the other drawing that explains and it has text to explain also.
Then you'll notice the pulse width 7.8 ms which agrees with my image up above. But you also see the references to the other pulse widths. On newer watches were there trying to squeeze maximum power from the battery they use an adaptive technology. If the circuit senses that the rotor hasn't rotated it will increase the pulse width as needed.  So for instance  around midnight where the dates indicated discs or the discs are required turning more powers needed the pulse width increases.
From a test point of view current consumption is extremely important when servicing quartz watches. If you block the train you'll see an increase in current consumption. If the pulse with changes you will see a tiny current increase. But not as much as if you block the train.  Then some of the technical sheets will actually specify to measure the current when it's not changing the calendar stuff but it might also give you the current when that's occurring also.
Out of curiosity where are you located?
Edited by JohnR725
Very nice document.  Magnetic brake depends on the rotor being sufficiently magnetized.  If not, I expect it would overshoot.  So back to my "most recent" theory, the rotor may be the problem.
33 minutes ago, KimBowers said:
Hi JohnR725. I'm in the UK.
Perhaps eBay new old stock movements I noticed they have two separate 963. Unfortunately the older circuit but. It looks like the problem is this is considered an obsolete watch and that makes it a challenge. But I would still go with the circuit only but if you bought the whole movement you'd end up with a rotor. But I still suspect it's only the circuit.
https://www.ebay.co.uk/itm/ETA-ESA-Quarz-Uhrwerk-diverse-Kaliber-movement-quartz-different-items-work/143916365749
John, if we are ultimately able to establish a winner in this contest...if I lose...I fly to Seattle and buy you a beer...or if you lose, you come to the GREAT STATE of TEXAS and buy me a beer?  ?
I know this was a page back (you step away for a minute, and there's three pages of wild troubleshooting fun!), but did I see correctly that a new movement of this type loses nearly a second a day? I never really paid attention to quartz watches (I have a phone and household appliances for that utility), and I thought it was more on the order of a second or two a year.
@LittleWatchShop, Where in Texas are you? I grew up east of Dallas, and used to know a ton of educated EE guys at TI.
Perhaps we need an experiment we need to find somebody that has few of these movements that doesn't care about destroying them I wonder who that would be?
The discussion has reached an interesting length hasn't it? If you look in the picture I posted the watch I had which is new old stock was a fraction of a second fast.Usually with the trimmer capacitors rated for seconds per month. Another experiment I could see how fast or slow they go if I rotate the trimmer. It used to be had know all of this by memory but it's been so long since I played with this particular model.
Closure at last !
I have received the 963.114 movement and transplanted just the circuit board and coil into my watch, keeping it's original rotor. And all is well. The watch no longer gains when warm or shows the jumping/fast second hand issue.
Many thanks to everyone who helped me sort this out.
Regards, Kim.
  • 2 months later...
We will never know.  Would have been fun to do some failure analysis on the board that was removed...alas...
What about failure analysis on running or other nonrunning but of the same caliber?
We also have your magnetic theory problem?
What if somebody had this identical watch you could test some your theories on it?
By if the rotor was demagnetized which sometimes can happen if somebody puts it on a demagnetizer and pushes the button like 1 million times or there may be some other ways to demagnetized it better than that.
If only we had a few spare movements like this?
2 hours ago, HectorLooi said:
What about trying this experiment on some cheap $2 movements? Remove the rotor and deliberately try to demagnetize it. It might even be better to use clock movements as they're bigger and easier to work on.
Yes we could try it on cheap watches but I think we should use the same movement is this one. Because by using a different watch or clock it changes things we need the same movement.
    • I assume you're using 9415? the concerned with 9415 and I'm attaching a PDF from Omega is too much can cause a decrease in amplitude. This is why you look at what they do they go to extreme lengths to put extremely tiny quantities. so as you've discovered proper lubrication of the escapement increases the amplitude. We've seen it on this group where people are having typically newbies issues and I will ask if they lubricated the escapement the usual answer is no they had not because and once they did they saw spectacular improvement. one of the amusements with lubrication tends to be so many variations. For instance I was in a classroom once and the students all came from for the most part accredited schools in watch repair. So the instructor asked how did we lubricate our escapement's and I don't remember the actual quantity but it's really quite amazing how many people can interpret slightly different ways of doing the same ask. Of course the instructors method was the approved one. This was the place a drop of oil on the impulse face of the exit stone. Allow one third of the teeth to go by and place another drop then another third and your escapement should be lubricated. But sometimes and yes it will show up in the timing machine you'll see in your regular line because if the oil didn't transfer all the way around to the other stone that does cause a issue with the timing machine. Oh but when I was in school we were using 9010 as 9415 did not exist yet although 941 did which is an oil recommended for escapement's. it has to be dissolved in a proper solvent with the right amount of concentration as you want a microscopic layer on whatever your treating. My understanding is the vapor process is the very best but the vapors are not good for human consumption. The reason why the vapor process is nice is that it puts a very very thin coating on versus dipping in a solvent which can vary depending upon the concentration.   8645_WI_40_rules for lubrication cousins.pdf
    • A modern restorer would probably try to inject adhesive as suggested and then weight the repair down. Some damp might have caused the bulge originally.  Traditionally the veneer would have been sliced and glue eased under the two flaps then again weighted back down and refinished once it had cured.  It doesn't look like just an adhesive issue, more than likely expansion of the veneer, worse case it needs a slice taking out. Try some gentle heat on it first , inject glue and weight, to see where it goes.
    • I have seen several mentions of steric acid, how do you use this, I have only seen it in crystal/powder form?
    • Hi @Michael20 I am no furniture man my self but it’s just bits and pieces I have picked up over the years. It just takes patience when dealing with things like the cases but most are veneered plain wood. When they get damp and open up that is a problem
    • I often get an amp drop after i oil the stones with 9415, not sure what difference can be achieved with oiling the teeth.  I guess the oiling surface is very small on a tooth as opposed to on the stones a larger drop might have more drag as the teeth plow through it. I oil with a bristle from a brush now, strangely enough the last movement i oiled five escape teeth and the amp was much higher than i usually get , coincidence ?
