BFG 866 Running Fast
I’ve put my BFG 866 movement back together today, give it a wind and set it going. Using the stop watch on my phone, the watch is running around 10 seconds fast over 60 seconds.
I’ve tried regulating the watch but it does not seem to make much difference and if I turn the regulator too close to the H/S pin the balance just stops.
I’m a little stumped here.... any thoughts?
Hello,
Check for fouling of the coils: they may be rubbing somewhere, reducing the effective length, or there is oil making them stick.
J
I’m obviously going wrong here somewhere.
I removed the balance and cleaned it in some essence and adjusted the spring collet slightly which allowed me to regulate it down to around 5 seconds over 5 minutes. However, if you look at the image below, it still looks as though the spring is too tight.... When I install the balance the impulse stone naturally rests between the pallet posts but the spring does not sit right.
As you can see by the way the spring is stretched out, it looks as though the spring needs unwinding??
When I received the new balance I had to rotate the spring so that the impulse stone sat between the pallet posts and I’m now thinking this is the cause of the issue???
    • Kalle Slaap said he is visiting London this week in order to see the exhibition. I was keeping an eye open, hoping to meet him.
    • Hello and welcome from Leeds,England.  Ask away.
    • What cutter are you using can you video the action
    • if you're trying to keep track of conversations scattered all over the message board emails are an absolute must.   looking at the bell icon on the top of the page versus the emails today it looks like I got the correct amount of emails. So making some minor change based on the one of the images up above I started getting notifications again. But at times I still have a suspicion that something isn't quite right. I have some feeling that the message board may delay sending emails until something so seems to be a long delay between when you get your emails just a weird feeling things aren't quite right oh  and then even though I do seem to be getting emails I no longer get notifications of personal messages I don't find that out until I arrived at the message board where I'm pretty sure I used to get notifications of those two. So something is definitely changed on the message board. then for everyone not getting emails you do want to check your spam folder. I have found that sometimes were open up an email the system I use warns me that it thinks the email is evil and bad and I have no idea why he thinks some of the emails are and some are not. But this is actually the program I use not the email system which also has a mind of its own as to what it considers spam so you should always check your spam folder.
