Pocket watch won’t regulate!
bosstaki
Hi guy’s, I’ve been trying to regulate this pocket watch for a few days now! It’s hours in front now! There no more adjustment left on the screw now & it’s running as slow as it can go! It’s for a friend of mine! The only thing i know about the watch is that he said he recently had a new main spring fitted & it’s been running really fast since he got it back from the jewellers! Cheers!
Can you check it on the timegrapher?
The logical action is to bring it back to who has repaired it.
Hi Bosstaki,
Yes, jdm us right. Bring it back to the jeweller's. However since you have the lid open already it doesn't do any harm if you take a strong loupe and check the hairspring spiral. Are there any two or more spiral windings sticking together? Then it's either dirt or the watch got magnetized somewhere. This shortens the spiral and makes your watch run faster much beyond regulation. If that's the case it's a relatively easy fix. Have you exposed the watch to a magnetic field somewhere after you got it back from the jeweller's?
Greetings from Hamburg,
Alex
Also, dip the hairspring in lighter fluid do around 15 min if there is oil between the hairspring leaves. Did this on the latest watch repair and it worked wonderfully. One-dip should also work. Also check the regulator pins. They may be too close together.
Run it through your de-magnetizer once or twice. They will run like a race horse if the hairspring is magnetized. That is the first thing I do if the complaint is running too fast. The hairsprings in old watches are susceptible to magnetization.
Check the amplitude. If it is very low, it will run fast.
1 hour ago, AlexanderToerzs said:
Hi Bosstaki,
Alex
Hi alex! Many thanks for the advice mate, the pocket watch was well magnetised mate! I give i a few goes with the demagnetiser & I’ve managed to get it regulated now!
I told him that he should have returned the watch back to the shop! He just wanted to take a look at it before he took it back! It turns out it was really magnetised! I passed it through me demagnetiser a few times! I’ve now managed to get it regulated! See picture! It’s the best I’m going to get it me thinks! Thanks for the reply mate
Magnetism for watches with steel Springs is always an interesting problem. Especially in a day and age when we have all these nifty electronic devices that have magnetic fields in them. Like things with speakers for instance. It's really amazed we don't end up with more watches magnetized.
then isn't that an interesting beat error? Doesn't seem like a little on the high side? Then out of curiosity what happens if you time the watch crown up?
That looks to me like a crazy high amplitude given how out of beat it is. The lift angle may not be reported but if you can find it somewhere, or calculate it manually, it would be interesting to know what it is. The trace is clean at least, so they did not do an absolute butcher of a job.
Indeed, not believable unless seen. With about 1.5 deg of amplitude per increasing lift angle deg it could be perhaps about 320, still very high. I think these are mostly academic exercises on a very vintage watch. If it runs well and keeps time that's all one really needs.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
    • Why cut the paper, cut a square around the image and grind to it.
