New Member Here
Joser
You have found the right place!  Welcome!  I recommend poking about here and getting a feel for the forum.  There is so much info here!  And such experienced folk, with hard-won knowledge that doesn't always appear out on the rest of the internet.  Enjoy!  Have fun!
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
