First Day
Pinetreepete
Hi. New to this modern world of community and not sure how it all works.
I have been repairing clocks for over 25 years and it has been a rewarding experience from the people I have meet to the numerous types of clocks I have repaired.Like most it just happened.Got an old junker got it to run and the rest was history.Along my travels I was blessed to be able to work with a watchmaker who survived the Holocaust due to his watch making skills.We shared true bond till the day he passed at 93.Hope to learn more and maybe share some of my experience.
Thank you
Pinetreepete
12/6/2020
Welcome to the forum. I'm sure you must have a wealth of knowledge. It will be us who would be benefitting from your presence here in WRT.
I only started repairing clocks late last year when a friend gave me a clock that he bought from an antique shop and couldn't get it to work. Since then I have learnt a lot from senior members here.
Cheers!
Welcome to the forum.  As Hector stated, I'm sure you're bringing a lot of skill and experience to our forum.  And I think you will have some stories to tell us as well.
I am still learning more, and getting more serious about this trade.  But I, too, began tinkering with timepieces long ago.  I have been learning piecemeal ever since.  Nowadays, I repair watches in my spare time, running my side-business through word-of-mouth, and I will often pick up non-running antiques and restore them to good working order so as to sell them for money to keep the business going.  As you might imagine, I sometimes keep a small few of these treasures, ones I could not bear to sell; that's my Longines in my profile pic.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
    • No thats straight out of the watch as i found it the balance wheel is almost as bad. I've never seen so much material removed.
