How does this bezel fit?
Bradders
Total newbie question (I think).
This watch is nothing special but it used to belong to my late Dad. It has a 17 jewel Basis movement in it which, from some searching is apparently the same as an ETA2824. The dial measures 28mm so I imagine I could easily buy a cheap 36mm Datejust style case for it but I’d like to keep it as much ‘My Dads’ watch as possible.
The crystal on it is actually plastic. It and the bezel came off totally and a jewellers locally had a matching replacement plastic crystal which appears to push-fit on (externally, by hand) snugly. I have no idea how the bezel fits. Is it supposed to be pressed on and that’s what keeps the plastic crystal falling out? Or is it to be glued? The inside edge of the bezel has a totally flat profile.
Any help or advice would be greatly appreciated. I’d like to avoid using a new case.
Si
Edited by Bradders
Hi Bradders does the bezel fit over the crystal? If not then a crystal should be fitted inside of the case edge. If the bezel fits that bezel does not hold the crystal in place, the bezel is very delicate and can be broken in half very easily. Just clean up the surfaces with some alcohol gently gently and use this glue in minute amounts and it can easily be removed if needed. Or use a similar contact adhesive. The on in the photo dries clear. Do not use superglue on any watch part hope this helps. Ps your dad's watch is special I am glad you want to keep it original.
Edited by Graziano
Thanks for your reply!
The original crystal and the new one both fit over the top of the case (not pressed in).
The external diameter of the origin crystal matches the internal diameter of the bezel meaning it fits perfectly but I have no idea how it was secured.
However the new crystal is slightly bigger externally than the original meaning the bezel either needs gluing or pressing to secure it. Or should I just be trying to find a replacement acrylic crystal that matches the old one both internally and externally?
Hi, if where my dad's watch I would try and return it to its original state. My advice would be to have an original sized crystal in place. Those bezels are  a dress bezel and can brake if forced. The crystal looks like it is pressed over the case, but if it's larger in diameter than the bezel then don't press the bezel over it if it's to tight. Hope this helps
You’re right I think it’s wise to just try and get an acrylic that matches the old one both internally AND externally and then use an adhesive to hold both in place.
If you get the correct crystal it should not need gluing, there usually put in with a crystal lift or a press, sometimes those bezels are pressed in but be careful. Have a good look under magnification and see if there's a lip around the edge of the case where it goes. If there isn't a lip then glue is ok. The one in the picture is cheap and available at any tool or hobby shop or watch material house.
Good shout! No lip on the case so it must be a glued acrylic I guess.
By my measuring it needs to be 31.6mm internal and no bigger than 33mm external to accommodate the bezel.
Thanks everyone for taking the time to reply.
My Dad died when I was 6 and this is the only thing I have. I recently acquired it so
its nice that it coincides with my new interest!
(And no, he didn’t hide this watch “up his ass” Pulp Fiction style before you ask lol)
Hi Bradders,
If your new crystal is just slightly bigger than the original one it still can be good. I am happy if someone corrects me on this but the old crystal is likely "set", meaning that it stuck in its pressed state and originally had slightly bigger diameter. What does slightly exactly mean in mm? I cannot provide crystals in the size you require - answering your question you asked me on a different platform -, I noticed that I have nothing between 32.4 and 35.0 and even if I would the internal height still would be a question mark. Cousins have sternkreuz HW above 32.4, the internal height would be likely good, but I cannot say that the crystal profile what sternkreuz HW has what you need.
Best regards,
lui
Edited by luiazazrambo
6 hours ago, Bradders said:
Having done a bit of extra Googling, I’m wondering if this is a ‘bezel fit’ crystal? Does the bezel act as a tension ring to hold it all together?
This one is a dress bezel looks the same but broken ? I will glue this one
16 hours ago, luiazazrambo said:
Hi Bradders,
Best regards,
lui
I might just have to try a few crystals. As long as they fit over the case AND the bezel fits around it properly, I’m prepared to use adhesive to secure them.
This is what it seems like. It doesn't seem likely that you will find a perfect crystal that matches both the required ID and OD; in cases like this I will turn up what's called a friction chuck, usually in Delrin, snap the crystal onto that, then with an extremely sharp tool in the lathe trim the outside (or inside as needed, in that case the chuck is a friction fit on the OD). If it is a snug fit on the case already then you won't want more than perhaps 0.05mm interference, i.e. your crystal OD should be that much bigger than the ID of your bezel. Even a little less as you will be checking the crystal on the friction chuck in an already expanded state.
Not having access to these sort of tools, I’ll probably resort to wet and dry paper to slim down the circumference of the acrylic crystal to accommodate the bezel and then use cement to secure both.
    • There is one Oris there at least, and if you could get a Unicorn for this price!??! 😄 It says that they don't work though, you might need to figure out what a Unicorn eats then. 😉
    • I wonder whats inside, bought it blindly, not cheap at all.
    • Here's a quick Gif I made to show truing the balance using callipers. This has such a slight wobble, but is within acceptable parameters. The important thing is the balance doesn't touch or rub anything when in operation. This is an Eterna Tank. Here's a pic of the balance freshly rivetted with a new staff in the movement
    • I just poked an inflation calculator, and $5 in 2020 would be about $6 in 2024. Doesn't fit very neatly into any status codes, which stop at 5XX, but that's honestly somewhat arbitrary outside of a clever pun for those that dabble in such things. Back during the pandemic, I would spend a good chunk of idle time in the evenings scanning through hundreds of listings a night, and I would only land 1-2 a week max. I would often go months without finding something suitable. A very small percentage of the watches in the price range are worth pulling the trigger on for my purposes. The number floating through the thread here may be somewhat deceptive.
    • Hi, guys I got there in the end after several attempts using a screwdriver and Rodico, I couldn't wait for the tool to arrive and was getting pretty confident handling the stud screw without it flying away. At first, I was using far too much Rodico, and then realized you only need the smallest amount inside the screw slot. Putting the cock back onto the movement also helped as it gave me more to hold onto while my shaky hand tried to align the screw wobbling away at the end of the screwdriver😁 Anyway, job done and I can move on. Thanks again for all the advice it's really appreciated for a beginner.
