Stuck brass movement ring
I have a brass movement ring stuck tight. Does anyone have experience removing such with care?
It's in a old Buren auto with a Durowe 611. You can tell the ring may have been beaten in by the dimples on the top edge. I've tried to gently pry it out all around but it is soft brass. I've tried to tap around its circumference inwards to dislodge it from the case. It's pretty dirty and it does seem to be more stuck to the case than the movement itself.
I've also tried to pry it away using the stem slot, which does have a inner lip, but to no avail. I'm worried about pressing too much on the movement itself. This is the first brass one I've come across.
If it was more stuck to the movement than the case I would just apply heat to expand it, but that likely won't work for brass on brass. Would some release agent be next to try? If so, which?
Thanks in advance for any suggestions or experiences.
DSC07265.thumb.JPG.8ef7b3a3db3335fdfef0f414156e13d1.JPGDSC07266.thumb.JPG.8fecc3ba7de5e682d072240bded49c44.JPG
I don’t like that the movement is there, but you could try inverting a can of “air” to release the cold liquid onto the ring and shrink it away from the case.
once it’s out, address the tight fit. Either it’s out of round or oversized.
Hi I would try the cold air method first or use plumbers freezing spray to try and contract the brass ring  if none available put it in the freezer for a while.  But before all that checkout Hectors assumption, It well may be a front loader as the vacant screw holes are suggestive of such.
Thanks all for the suggestions. I'll first try contracting the ring with a can of compressed electronics duster and/or the freezer. If still stuck in there, I'll just remove the crystal to make sure it's not a front loader although there are a couple of indications it's not. I'll definitely address the fit once it's all cleaned up.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
    • No thats straight out of the watch as i found it the balance wheel is almost as bad. I've never seen so much material removed.
