Fake Rolex
a customer brought in today a couple of watches needing batteries and a rolex watch his brother bought with ill gotten gains somehow ending up in my customers possession. I didnt ask.
So i was charged with assessing whether the watch was authentic or fake.
I looked at the dial/hands under the microscope and that area looked pretty legit.  I got out my rolex opener, took off the bracelet and opened it up to see the mechanism. No no.  The 2 red gears of the automatic mechanism were chipping paint.  The decorative swirl pattern on the plate/bridges looked like a kid did them.  And the overall finish of the edges of bridges/plate was horrid.  Also hairspring didnt have that weird swirl that looks like a kink, and the balance wheel was lacking those knurled setting nuts.  And the incabloc spring for the balance looked odd.  Nothing inside had that swiss precision of fit and finish.
He said his bro paid $700 dollars for it.
Ive got the very same 3135 rolex disassembled on my bench right now in covered trays so i showed my customer the difference in the quality under the microscope. And theres also very slight differences of bridge shapes.  Especially the balance cock.
2 hours ago, Tudor said:
Although the replica 3135 runs ok after a service, it take about a nanosecond to realize your not looking at anything from Switzerland.
The dial and hands were pretty well finished under the scope.  Thats what got me.  I thought the bracelet was a bit flimsy but it really wasnt until i opened it up that i knew pretty quick it was a repro.  However.  I agree i did see potential for overhauling.
i think that these "good quality", expensive fakes are the worse ever in the counterfeiting industry, and should be fought with full energy.
The reason is that they can easily be the enabler of actual scamming, where a victim that honestly doesn't know better is had for thousands of dollars.
These are not just the cheesy fetish of poseurs that find smart to spend more on a fake than on a bespoken genuine piece.
A lot of fakes are worthy of merit in their own right. Why they have to spoil it for themselves by using somebody else's name is beyond me. They are not going to sell for any more.
It's not just the scammers who are to blame, the likes of Facebook supports them with sponsored ads. My FB is swamped with scam adverts.
I read these Rolex with asian 3135's are pretty expensive and aren't as good in quality as the ones with a Swiss 2824/2836 movement. Only thing is the tube and crown are in the wrong position with the latter. It seems on the newest Asian VR3135 versions parts are pretty good interchangable
    • I am pretty sure the correct practice to insert a tensioned crystal is to use a crystal press - although I always hate doing it as one slip and the crystal can skid across your dial, this happened to me on a Tissot, mangled all the hands and scratched the dial down to bare metal. I much prefer to remove the bezel and install the crystal into the bezel and then the bezel back onto the watch, not sure if this is an option for you?
    • Well, Geiger counter showed up today and the dial and/or hands were extremely radioactive, reading quickly spiked from a baseline of 10-20 cpm to 100 and was still rising when I removed it. Trashed the whole thing. Thankfully nothing else outside the components was registering - work surface, tools, the paper I had used to clean off some components....    And now I have a Geiger counter to use to  check practice watches BEFORE disassembly
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
