Here's some information on the output of the Cousins LED light as measured by a lux app on my IPhone.
This light is fitted with two rows of LEDs that can be both individually selected and dimmed. The readings were taken with my phone 10" below the light as this is the height I have it when working on watches. I also measured the light colour temperature at the different settings.
One row low setting 1,240 Lux ......... 6600K colour.
Two rows low setting 3,960 Lux ......... 6000K colour.
One row high setting 5,450 Lux ......... 6300k colour
Two rows high setting 20,800 Lux ....... 5600K colour
To give an idea of how it compares with the Cousins small portable fluorescent desktop lamp that I have currently been using.
At the same distance of 10" it gave 3,170 Lux .......5600K colour
At a distance of 5" it gave 30,600 Lux ....... 5600K colour although there was a bright hot spot with rapid fall off at the side. This was the the distance I have been using, and it was a nuisance as it often got in my way.
This has been the best improvement I have made regarding equipment this year. Please remember that these tests are for guidance only as I have not used specialised equipment. I hope you find the information useful.
Here's some information on recommended lighting.
Well cousins conveniently removed the branding from the box. (Just a thought: Did someone find it cheaper online and call them out?)
But here is a pic of the tag on the lamp itself.
Hope this helps
Thanks, Mark. Based on the model number,  I found them for sale in Russia and Poland. Strangely not in China. Prices (ex-delivery) approx. £56.2 in Russia and £53.8 in Poland. If anybody interested, I can try to find cost of postage.
Isn't Internet wonderful thing?
Following Rob's link to the model I note that the manufacturer offers samples - see on right under model name. If any of you has a legit company then this might be a way to collar a few lights at a competitive price. You could sign a few of us up maybe? :-)
It is a broad strip-light giving fore and aft shadows. I see them in your photo George, admittedly fairly faint. Is it not better to have a circular light source? Mine is a neon tube but surely it must exist now with LEDs? But if not, then this one is the nbt..
Hi Colin, without having a circular light to compare it with I can't really make comment. All I can say that working on movements has been a lot easier since I installed it. I'm sure others will pitch in when they start using them.
Would you not have to look through the centre of the light as a camera would with a ring flash fitted, to get the result you are after?
I really don't think you would be disappointed with the linear light fitting Colin.
This light is 50 cm diameter and would be placed slightly above head height so as to be able to work underneath. Then there is the problem of shadows from the hands, but on account of the distributed light source these would be less obtrusive than from any other more localised source.
Yes, George, I am sure that the Cousins light is the best at present on the market for fitting to the bench and I shall buy one for my lathe workshop bench that now has a miserable expensive LED spotlight sold for professional machine use, but very heavy on shadows.
Maybe I shall give the circular one a go for my watch tinkering table, although for this, during the daytime, I have hard-to-beat overhead daylight from a roof Velux - except after snow, and we have had plenty this Winter!
    • Just missed it! I have a donor movement on its way. But thank you for the offer--I'll let you know if I need anything else.
    • My latest. Timex 2465. Replaced the crystal, caseback gasket and spring bars. All in less than $5US. Added a gray NATO strap I already had in stock.
    • I have some Gruen 510's in my donor pile if you need parts.
    • I've been intrigued by everyone's input here...so I decided to give this a shot. I bought the"typical" Pearl watch-machine basket and trays, for about $65. The trays are good,..the housing is a nightmare ! Thought it would take the mixer off my bench at anything above about 200rpm. The housing is cast of course,..and it's not "true" at all...so the harmonic vibration was insane. So,..I bit the bullet and bought the Elma housing and top. Not the baskets though, as the Pearl one's fit the Elma. Saved a bunch there. The basket and lid came to about $80 with shipping. The opening in the Elma top is 8mm, and the shaft that came with my stirrer is 6mm. I bought a piece of steel tube, 8mm O.D., and 6mm I.D. Cut off about an inch of the tube, and drove the rod into it. Gives a really snug fit.... Lightly champfered the leading edge of the 8mm section, then lightly tapped it into the top of the Elma lid. Spins like a dream now So... I have about $240 total into this including jars and steel mesh for the wave breakers   I'm pretty happy Best to you all   Randy
    • Still haven't gotten around to getting stems or screws, but I did make my first attempt at polishing a case. I just used a soft mop and rouge to reduce my odds of ruining them, and I think they came up pretty nice. Also gave the crystals a polish on the same wheel while I was at it. They were both very badly scratched up. The one on the left is fairly beat up, but it'll still make for a decent presentation.
