ETA 1120 Centre Wheel Problem
JimXgates
Good evening folks.
I was asked to repair the above movement. Firstly when it was opened there was a 'paint deposit' in the movement. I cleaned the movement and associated parts and managed to get the watch accurate to +5 secs a day. I was fair chuffed. However, when winding the watch it was extremely difficult and I looked at the movement of the winding wheels. I re-stripped the watch and looked at the centre wheel arbour. It was scored and had excessive lateral movement within the main plate. My question is this, I have ordered a replacement centre wheel do I have to re-bush the main plate.
I look forward to your responses.
Thanks
Center wheel is the second wheel that takes motion from the barrel, should have nothing to do with difficulties in winding, so perhaps you mean something different?
Hi in order to eliminate what could be two problems,  remove the Min wheel and canon pinnion and try the winding and hand set motion again if its still tight look further into the keyless mechanism..   Regarding the second wheel side play in the plate, if as you say its excessive its more likley that the plate has worn and will require a new plate or a bush but in either case both the wheel and plate will require attention,     Tech sheet attached
1876_Eta 1120.pdf
Further to this problem. I have cleaned all the parts, removed the cannon pinion and the minute wheel all the keyless mechanism is working as expected. When the cannon pinion is refitted it doesn't click onto the centre wheel arbor and the keyless work is extremely difficult to turn. Should i replace the cannon pinion or am i missing something else.
So if i am reading this right every thing is ok untill the cannon pinion is fitted ? . When you say the cannon pinion doesn't click on to the center wheel arbour, Is there no pronounce feel as it seats and when it is fitted it is again stiff to turn the hands.  There should be some friction to allow the hands to drive as normal but not so stiff to make it hard to set the hands . If its too tight then a turn of a broach may help by removing some of the metal insde the cannon, but great care must be taken not to over do it, or alternativley replace the cannon pinion.
Before broaching put some oil on the arbour, refit canon pinion, it will feel dificult to turn at first, keep turning and it will ease up.
This might be all it needs, if good results, you then should clean and apply grease instead of oil.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
