How to measure case back allen screw?
firebynight
I'm trying to open a case back secured with allen screws, but I've tried multiple sets (none of them are actual watchmaker specific) and no size fits exactly. I'm afraid to strip the screw with an ill-fitting allen key. How do I measure the screw and make sure I have the correct size? Is there something with special sizing of allen keys used on watches/case back screws?
Thanks!
If you use your calipers you can measure across the flats of the socket. That’s the size. Convert the direct reading to the other (inch to mm or vice versa) and get the closest size under.
I would be very surprised if they had unique size hex heads made.
Edited by Tudor
Sorry for being so obtuse, @Tudor @rodabod --
 What are the flats that I should measure?
  1. from rounded edge of the head
  2. from angle to angle of hexagon
  3. from edge to edge of hexagon
The main problem with this is I'm having difficulty even getting into that space with my calipers to measure any of these spots.
I ordered a hex set from Esslinger. And none of those fit.
I even resorted to going to the hardware store to try and see if they had any allen keys that would fit. Nada. Closest I found was a torx marked TT8, but then even among other TT8, they seemed to differ and not fit. ?
Number 3. Flat to flat.
I see it is not very deep a socket either, so once you find the right size, you'll want to dress the end of the tool to keep the corners sharp to avoid rounding out the hex.
Maybe heat the screw with a soldering iron first too, in case there is any threadlocker in there.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
    • Thanks for the info. I can't seem to find tech sheets for those either.  I'll muddle my way though 🙂
    • Ohh spooky I have just aquired the same one mike, but mine has a drill bit inside it.
