Harley Ronda 726 parts pdf.
Len33
Not long ago, somebody on here kindly provided me with a complete parts list pdf for the Harley Ronda 726 chronograph.
I thought I had got it safely saved but, like a click spring, it has vanished into thin air!
Any chance of another pdf, please?
Hi  Joe  Under the heading resources there could be put a heading to enable us to either drio in the link,  or the PDF's as we pick them up,  Maybe one for the future. I have a fair collection on my machines and would willingly put them up.  Google drive  I belive is a source on the net.
Hi Weasol, I remember my words in my first PM to you;
" What is easy for you,  might seem impossible to someone else"
Ease of access and simplicity to understand are keys to education for all.
Perhaps you find some way, a lesson and simple instructions, flow chart ....on how to access the files, is a key, however, the universality of the key may start with the title flashing off-on before the seeker eyes.
One might have the potential to become a master horologist but not understand a word of computer stuff.
Best wishes Joe
1 hour ago, Watchtime said:
@Nucejoe @watchweasol Good point, maybe we can ask Mark what we can do, some kind of library
It has been discussed before and the idea is not walking, for one side it requires maintenance work, for the other usually this type of documents can be found with a simple Internet search.
Quote
In case there is a possibility to share  here on WRT, I am happy to upload my collection of a few hundred service sheets....
Nothing prevents you from attaching them to a new topic with as many postings are needed. Then you can ask moderators to pin or star the topic.
Edited by jdm
    • Maybe you had a bad one H, the cheap blue one i use has been fine for nearly 3 years now. It demags enough to stop the tiniest of screws sticking to the carbon steel tweezers i use. If it were to fail at some point in the future i very  probably would go up a level of device just because.
    • Lot of “industrial “ de magnifiers on Aliexpress  https://www.aliexpress.com/item/1005004699640024.html?src=google&src=google&albch=shopping&acnt=708-803-3821&slnk=&plac=&mtctp=&albbt=Google_7_shopping&albagn=888888&isSmbAutoCall=false&needSmbHouyi=false&albcp=17858129175&albag=&trgt=&crea=en1005004699640024&netw=x&device=c&albpg=&albpd=en1005004699640024&gad_source=1&gclid=CjwKCAjwo6GyBhBwEiwAzQTmcxIEVpMt1vFIKQyfjVwT95zrBsOi5dt-GgFOmLamBcMcu4tO7CfaaxoChnEQAvD_BwE&gclsrc=aw.ds&aff_fcid=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&aff_fsk=UneMJZVf&aff_platform=aaf&sk=UneMJZVf&aff_trace_key=b7140f118e144db7876d074872aec9cb-1716029308364-08531-UneMJZVf&terminal_id=6b7c60e41b044cb39d1431f62cda0958&afSmartRedirect=y   a hard drive wiper/degauser would also be worth looking at.   Tom
    • Unfortunately yes! Magnetism can wreak havoc on a mechanical watch movement if the balance hairspring becomes magnetised. The cheap blue Chinese demagnetise-rs are useless if you feed them the wrong voltage (> 110 V), and even so, they don't work very well. The one I got when I was new worked so poorly that it drove me nuts. Eventually, I was lucky to get a Greiner Magnomatic for a little money. It's an amazing tool that can be trusted to do its job perfectly in seconds. A new one comes with a price tag of  £885 excluding tax and shipping, and if you think that's a bit steep (I believe most of us would) and can't find a used one I'd go with @Jon's recommendation.
    • Yep Mike , i use exactly the same gauge for it.
    • You definitely pick up different names from different people of all ages from everywhere. Like learning different dialects of the same language. Its all part of the learning curve of any trade.  Both those two terms describe to me perfectly that they are one and the same. After a couple of years of knowledge you can figure out what is being talked about. There are times that i get caught out with something i haven't encountered before.
