Hi Hector  I too are foremost a clock man, enjoy the variety of movements and types and as you have noticed they take a bit more care and attention  if you are to retain all fingers injury free,  See if you can get a cuckoo clock  they are fun, they have musical boxex and carousels and cone in a variety of styles you could fill the house.
When you get something like this in your workshop, you will know working on clocks makes it all worth while. I loved these types of movements and Longcase clocks.
  Old Hippy you were a very lucky man having spent your life time working with clocks like these,  Judging by the look of the movement there was a lot of hand made parts. They were truly a work of art and engineering and well worth preserving for the future in this throw away era we live in.  The amount of pleasure in restoring one of these clocks to good health, one can only imagine.
Hi OH,
A million years from now, folks will study this dinasour-caliber and wonder if it ate its own kind.:o
1 hour ago, watchweasol said:
They will study it and wonder at the skill of the maker, as by then it will all be plastic and electronics.
The question they will have still remains unanswered.
What did it feast on to grow so big?
I have had the privilege of handling such wonderful movements. People in say 500 years’ time will only be able to read about them or see such wonders in museums.
Hi OH, some already are munseum piece.
This a present from Queen victoria to the palace of the king in Tehran,  was considered to do much better if the public saw what britts built back in those days, so was installed in a bussy square for all to see, received regulare service and was working until just recently when taken down for a major overhaul, thereupon will be put on exhibition in museum I have heard.
I got my clock all assembled and synced correctly. But when I  put the movement back into the casing, the chime and strike doesn't work properly. It's like the post of another member who says his clock only chimes 3/4 of an hour.
I studied the movement for the past 2 days and came to these conclusions:-
1) The silent lever has something to do with the problem. If I move the lever to "silent" then back up to "chime", the clock starts chiming again for another 3/4 hour.
2) The 2nd detent which engages during auto-correct position is not being lifted high enough by the long spoke of the cannon pinion wheel.
I have to decide how to ensure proper release of the 2nd detent when it engages the locking pin.
Looks like it's going to be another sleepless night. :wacko:
Sounds like the silent/chime lever is somehow rubbing against something when in the case, make sure it is only touching what it needs to touch and that is all and it sticks out through the slot in the dial with ease.
I managed to get the clock working and chiming away happily for over a week. I received another Smiths mantel clock on Thursday. I have it stripped down and ready for cleaning already.
I noticed that after soaking in white spirit, the brass looks dull. I have been experimenting with soaking it in a dilute citric acid solution for 15 minutes after the white spirit soak. This brightens the brass significantly. Does citric acid damage clock parts?
I have used it sparingly on badly stained brass it will remove black spots from brass that Ammonia cleaners wont but you should generally avoid its use it can react with the copper in the brass and produce patchy pink stains on the surface so its not suitable as a general brass cleaner. It is very good at removing rust when parts are soaked in a weak solution.
As wls1971 says I would avoid using citric acid in clocks.
Get a scap bit of brass and drop it in some citric acid and leave it in there for 20 minutes and come back and it will be copper colour which then takes significant polishing to remove, it is essentially dezincing the brass, or causing dezincification which is damaging the brass.
I used to restore toy and model steam engines and dezincification was our worst enemy, now don't get me started on the differences between using distilled water and de-ionised water in brass boilers as that is an even hotter topic for toy steam engine collectors than whether to sharpen your screwdrivers with hollow ground or flat edges is to watchmakers. :Laugh:
    • Sorry @nickelsilver, I'm just seeing this now.  It is a standard metric screw plate. I followed the suggestion of doing the thread cutting in a pin vise.  It took me forever because the piece is so delicate that I cut and cleared chips very frequently.  But eventually I did get it.  Not pretty, but I got it; the first thing I ever successfully made on the lathe. I cut the screw slot with a jewelers saw.  How can I ensure that the slot is centered on the screw head?
    • Hello, My name is David and I’m a vintage watch collector/ wanna be hobbyist watchmaker from France. I really want to progress into my watch repairing hobby. For now, I’m only having fun servicing my own watches and spare movements, simple small 3 hands from the 50s (Omega, eterna…) Learning step by step or at least trying to 🙂
    • More setbacks and successes...  After letting the watch run in (but before I fixed the BE) a chunk of the radium lume fell off one of the hands and pulverized leaving radioactive dust all over the dial 😞 ☢️ ☠️ So before I could continue further I decided I would remove the radium lume.  I have removed radium lume from hands before where it was already starting to flake away but this time I had to work out what I was going to do with debris on the dial.  I decided that getting everything under water and removing all the lume was probably the best way to go. So here is what I did... I put an essence jar I use for cleaning parts and filled it with water and put it into a big ziplock bag along with the tools I would need - a sharpened piece of pegwood and  a 0.80mm screwdriver  -  I put on a pair of nitrile gloves and a covid style mask and then opened the back of the watch. Now with the back off the watch I could do the rest inside the bag.  I removed the watch from the case and removed the hands from the dial (through the bag) and then undid the dial screws and removed the dial from the movement.  I then put the hands and the dial and the watch case into the water and removed the movement from the bag.  Carefully and slowly with one hand in the bag and one hand trying to poke and hold stuff through the bag I gently rubbed away the lume from the dial and hands with the pegwood. I then took the parts out of the water and removed the jar from the bag (leaving the parts still in the bag) - with the majority of the dangerous stuff now in the water I disposed of this (down the toilet) and gave the jar a good rinse in running water before refilling it and returning it to the bag where I gave all the parts another rinse in the new water.  I then took the parts and put the geiger counter over the top of them and looked at them carefully under UV light to see if there were any flakes still hanging on. I dried everything with some kitchen towel. Once I was finished will all that I remved the parts from then removed the gloves and put them in the bag with the paper towels and the pegwood and thew the bag in the household waste. Finally I gave the dial, hands and case another rinse in the sink under running water.  I didn't bother following up with a rinse in distilled water water because the water here is pretty clear of limescale etc and I find it doesn't mark! So here are the results of my weekends work! Timegrapher dial down (dial up is almost the same) The fixed shock setting New crystal - and lume removed from dial and hands
    • Hi and welcome! I'm new here too—greetings from Leicester, UK.
