Hi all,
Just started disassembling a Gruen pocket watch with a Unitas 285 movement, Gruen 497. It's very similar to the Unitas 6487 but has a date. The ratchet wheel screw won't unscrew. The movement is clean - no rust to speak of - so I know that can't be the culprit. I have used a lot of force and no progress. I assume this is a regular right-handed screw unlike the crown wheel which is left-handed. Any chance this ratchet wheel screw is left-handed? Any other suggestions will be greatly appreciated - Thanks!
Hi Dan, Proceed with the strip down, remove the train bridge, gears and canon pinion, barrel then comes out attached to it bridge, soak in coca cola for two days, unscrews easy  then.
One advantage of coca cola is it lets total submersion and cheap. How else penetrants may get to arbour and the thread of ratchet screw?
Do not drop the movement in coke yet.
Regards
Thanks for the suggestion. When I have just the bridge with barrel attached, should I remove the mainspring, or soak with it inside the barrel? If I try to remove the mainspring before the soak, I'm thinking it may be a little tricky to detach it from the arbor, though I'd feel better not soaking the mainspring in coca cola.
Hi Dan-do looks like a nice clean movement. did you try to give it a nudge clockwise to feel any resistance or tightening? don't force it. I've not seen a left handed ratchet screw but you never know.  do you have any kind of penetrant laying around and oilers? maybe some lighter fluid? once you get the bridge with barrel assy. out, I would apply penetrant around the screw head, then turn it over and apply more at the barrel arbor, and a few more dabs to the holes(if any) thru the barrel cap and let it sit. better if over night, checking on it once in awhile. if that doesn't work, I might let it soak in lighter fluid(naptha) for an extended period. overnight is best, checking on it, seeing if it frees up. if all that fails, give the thing a short rinse in iso alcohol to dry it completely. at this point, you might have to add a little heat such as a jewelers lamp if you have one, or a cig lighter. apply the heat SPARINGLY, with the flame about 1/2 to 3/4 inch from the screw, using a circular motion. in other words, don't hold the flame in one place, keep it moving. you don't want to overheat the thing and run the risk of burning fingers. also, make sure your screwdriver width is as close to the width of the screw slot as possible so as not to slip, gouge, scratch or damage the slot or anything else and don't force anything.
no expert here-just a couple things that have worked for me. try these and get back to us. good luck.
Mike
Hi Mike,
Thanks - I'll give the penetrant a try. I was also thinking of running the bridge and its attached barrel assembly through the ultrasonic using the extra fine watch cleaner and cleaner rinse to see if that loosens it up. I'm thinking this can't hurt, though my one worry is, what if the micro-shaking of the ultrasonic loosens the barrel arbor cap and the mainspring then goes flying?
This stuck screw is such a surprise given the condition of the movement (no corrosion). Could be the last person to work on it just bared down too hard when tightening it.
Dan
27 minutes ago, DanB said:
Hi Mike,
Dan
hey, 400 lb gorillas are more common than you think! yes, the ultrasonic gig you speak of is fine and might work even better. the chance, I believe, of the assy. trying to escape and go flying, are slim to none. with that cantankerous screw especially. even if it did, you won't lose it. just make sure to watch your eyeballs for flying objects! what size is the movement? also I should let you know that when I use my ultrasonic to clean parts, the solution I use is, yep you guessed it, naptha. parts into screen containers, screen containers into jars with naptha, then parts, containers, naptha and jars into machine filled with demineralized water half full and let er buck. so, I think you're right  on the money.
all that being said, we shouldn't forget that this hang-up might not be seized screw at all but something more mechanical in nature such as seized or cross-threaded threads, somehow jammed up mainspring, or the whole dang train is jammed up with broken teeth or broken leafs on a pinion gear or worse. so exercise caution, make periodic checks and close inspections of the things, see if the elusive misfit reveals  itself.  I love beating an "overconfident gremlin." keep us posted...
It's a 16.5 ligne/36.6mm movement. It really is almost identical to the ETA/Unitas 6497 except the motion works are at 12:00 since it's a pocket watch. I didn't think that the ratchet screw could be cross-threaded which would really make it stick if it is, but based on how flush it's lying to the ratchet wheel, that may not be the case.
The good news is I have a spare parts 6497 movement to call upon in case anything gets really botched up related to the barrel and arbor, so there's not much to lose by trying different techniques. Plus the watch was passed on to me by a friend who knew of my recent interest in this stuff (so nice when that happens) so it's not an heirloom or anything extremely valuable.
Thanks again for weighing in.
Dan
Two days soak in coca cola wont hurt any metal, the suger in coke, however, may crystalize which is a pain to clean if inside the jewel hole. Personaly exclude hairspring and jewels and soak the rest.
The concern with removing the barrel and mainspring(MS) when still attached to the bridge is MS jumps out violently as you try removing the barrel and leave the arbour and lid still attached and spindle may break. If you plan re-using the MS, you would need to clean it anyway, which if manually I recommend with a brush and not cloth.
Mike
No heat specially flame, unless you discard the heated part. I do use heat( soldering gun)  on stuck broken screw thread since I don't collect broken screws.
I'm wondering that too.  Physics being what it is, if the crown wheel screw was left-handed, then the ratchet gear screw couldn't be.  But!...if the crown wheel screw was standard, wouldn't the ratchet gear have to be the one to be left-handed?
No. The crown wheel screw may be be left threaded because the crown wheel, which turns counter clockwise under it, may tend to undo it. But the ratchet wheel screw does not move related to the ratchet wheel and barrel arbor airbor, no need for it being special, no matter which direction it turns.
That being said, if left threaded  the manufacturer gains commonality of two machining steps, and of two parts if it's identical to the crown wheel screw. To the cost of confusing most repairers as happened here,  and the risk of an unpleasant breakage. At least, both of them should have three slots not one.
Hi all,
Mystery solved - the ratchet wheel screw is left handed. Wow. I briefly thought that could be the case, but still being new to this (just under a year with the tweezers) I assumed that most if not all crown wheel screws are left handed, ratchet wheels are right. Oh well, lesson learned. I looked for technical info on the movement on the AWCI site but could only find parts info. I should have checked the Ranftt page sooner (thanks Klassiker for that reminder).
So the screw is out now, no damage done.
Thanks again to all.
Dan
Hi all,
Dan
Good thing you posted this thread,  saved the watch and can drink the coca cola too, don't forget the pop corn.:lol:
2 hours ago, DanB said:
Hi all,
Dan
left handed threads for the win!:Bravo: how did you get it? did you nudge the screw clockwise and it began to move? good stuff for future reference.
Edited by MechanicMike
wrong word :)
Yes, I nudged it to the right and it didn't take much for it to loosen. I had applied Marvel penetrating oil to the screw and let it sit overnight so that might have helped. At the outset when I didn't know it was left handed, I did give it a little nudge to the right but it didn't move and I didn't want to make matters worse if I nudged too hard.
I did buy a can of coke just in case and now I can enjoy it with some popcorn!
  • Haha 2
    • Sorry @nickelsilver, I'm just seeing this now.  It is a standard metric screw plate. I followed the suggestion of doing the thread cutting in a pin vise.  It took me forever because the piece is so delicate that I cut and cleared chips very frequently.  But eventually I did get it.  Not pretty, but I got it; the first thing I ever successfully made on the lathe. I cut the screw slot with a jewelers saw.  How can I ensure that the slot is centered on the screw head?
    • Hello, My name is David and I’m a vintage watch collector/ wanna be hobbyist watchmaker from France. I really want to progress into my watch repairing hobby. For now, I’m only having fun servicing my own watches and spare movements, simple small 3 hands from the 50s (Omega, eterna…) Learning step by step or at least trying to 🙂
    • More setbacks and successes...  After letting the watch run in (but before I fixed the BE) a chunk of the radium lume fell off one of the hands and pulverized leaving radioactive dust all over the dial 😞 ☢️ ☠️ So before I could continue further I decided I would remove the radium lume.  I have removed radium lume from hands before where it was already starting to flake away but this time I had to work out what I was going to do with debris on the dial.  I decided that getting everything under water and removing all the lume was probably the best way to go. So here is what I did... I put an essence jar I use for cleaning parts and filled it with water and put it into a big ziplock bag along with the tools I would need - a sharpened piece of pegwood and  a 0.80mm screwdriver  -  I put on a pair of nitrile gloves and a covid style mask and then opened the back of the watch. Now with the back off the watch I could do the rest inside the bag.  I removed the watch from the case and removed the hands from the dial (through the bag) and then undid the dial screws and removed the dial from the movement.  I then put the hands and the dial and the watch case into the water and removed the movement from the bag.  Carefully and slowly with one hand in the bag and one hand trying to poke and hold stuff through the bag I gently rubbed away the lume from the dial and hands with the pegwood. I then took the parts out of the water and removed the jar from the bag (leaving the parts still in the bag) - with the majority of the dangerous stuff now in the water I disposed of this (down the toilet) and gave the jar a good rinse in running water before refilling it and returning it to the bag where I gave all the parts another rinse in the new water.  I then took the parts and put the geiger counter over the top of them and looked at them carefully under UV light to see if there were any flakes still hanging on. I dried everything with some kitchen towel. Once I was finished will all that I remved the parts from then removed the gloves and put them in the bag with the paper towels and the pegwood and thew the bag in the household waste. Finally I gave the dial, hands and case another rinse in the sink under running water.  I didn't bother following up with a rinse in distilled water water because the water here is pretty clear of limescale etc and I find it doesn't mark! So here are the results of my weekends work! Timegrapher dial down (dial up is almost the same) The fixed shock setting New crystal - and lume removed from dial and hands
    • Hi and welcome! I'm new here too—greetings from Leicester, UK.
